Old 11-12-2011, 12:31 PM
CarBiz's Avatar
CarBiz CarBiz is offline
Originally Posted by CC1650Dave View Post
I also need to get the boat winterized this weekend
Naw there is still time left for one more run!!!
Old 11-13-2011, 04:54 PM
CC1650Dave's Avatar
A'right boys, here's the rundown on today's troubleshooting:
1) Re-checked the spark plug. It's the Autolite 216, gap is at .025. Cranked the engine with the plug out and saw a good blue spark. Reinstalled the plug. Tried to start, same problem.
2) Went to Napa and purchased a new set of points and condenser. Reason? The condenser was the one that was on the tractor when I got it, I have no idea of its condition. The points were the ones that came with the rebuild kit, and they just seemed flimsy to me. So I wanted to eliminate them as a variable.
a) Tried the new condenser first, without changing the points. Tried to start, same problem.
b) Swapped in the new points, re-did the static timing. Tried to start, same problem.
c) Just a note for reminder, in case it strikes anyone as problematic: When I initially put the points @ .020, they break at TDC, when the "T" is in the sight hole. I have to bring them all the way out to around .040 to get them to break at the "S."
3) Swapped out my coil and spark plug wire with the ones from the K321. I noted that my coil, when inverted, had an oily liquid dripping out where the plug wire goes in. The plug wire itself was kind of wet / oily here. That doesn't seem like it could be a good thing. So I'm thinking maybe this is the problem. K321's coil and spark plug wire in place. Tried to start, same problem.
4) Now, moving away from the more obvious components, I went to a suggestion Duke gave me and ran a jumper wire from the positive side of the battery to the positive side of the coil. This will let me know if there's a problem somewhere between the key switch to the voltage regulator to the coil. Tried to start, and it did start easier.
Now, this could be because I had the tractor running for a little while on one of these previous hard starts, so it could just be starting easier because it's warm. But it did seem better. I'm going to let it cool down while I watch some football, and try it again later.
Fingers crossed...maybe we've narrowed down the problem!
Old 11-13-2011, 06:25 PM
EricR's Avatar
EricR EricR is offline
Dave sure hope that's the problem and you got it fixed.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 11-13-2011, 08:29 PM
Sugarmaker's Avatar
Dave,
Thanks for the update on the hard starting engine. You were busy! I will be watching for the final fix.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-13-2011, 08:34 PM
CC1650Dave's Avatar
Nah, I went out and tried it again 3.5 hours later, and it's still a really hard starting engine.
So we're getting closer to the possibility that the impossible happened, that the cam and crank are off by a tooth. As much as I paid attention to that, all of the symptoms sure seem to point to it.
I have the K321 sitting on the bench waiting for takedown / rebuild. I think I'll open it up and try putting it off by a tooth on purpose, and then see if it's possible to get the points to open on the "S." That'd answer the question I posed in this thread...
Old 11-13-2011, 08:38 PM
CC1650Dave's Avatar
Question: Once I actually get it started, it actually runs pretty smooth, and it'll accelerate nicely from mid-throttle to wide open. It vibrates quite a bit at idle and mid-range, but smooths out nicely at wide open.
Could that be the case if your cam and crank were off by a tooth? It seems like it wouldn't be smooth at any throttle level (?)
Old 11-13-2011, 08:47 PM
Sugarmaker's Avatar
Dave,
Really wish I could help on the off by one tooth idea. I guess I would be surprised that it would run good after starting? I am not going to speculate on this. I am not a expert in hard starting. Question? Can you take off the cam cover and see the timing marks? I though I looked at mine thru there? But maybe I dreamed it?
Regards,
Chris
Old 11-13-2011, 09:00 PM
CC1650Dave's Avatar
I dunno Chris - it doesn't seem like I'd be able to. I was thinking maybe I could get one of those little inspection cameras in there thru the cam cover or fuel pump hole - if I had one...
Old 11-13-2011, 09:18 PM
Dave the plug should be gapped at .035 for electric start.
Maybe see if you can rent a inspection camera?
Old 11-13-2011, 09:32 PM
CC1650Dave's Avatar
Really? The 1650's owners manual shows .025", and so far I can't find any IH or Kohler source that says .035". You don't think that'd make the difference do you? I was thinking the same on getting a camera on loaner...
Chris, I just pulled the cam cover off the K321 that's out on the bench, and no, there's no way to see where the gear matches up to the crank.
