Old 05-16-2020, 02:21 PM
Originally Posted by Rwgarrison23 View Post
What did you do to fix it? Get new head?
Originally Posted by ironman View Post
Answer, yes.
I think if I blew the plug out of a Kohler head,,
I would buy a drill and tap for an 18mm plug and simply install the larger plug.
IIRC,, the Ford 8N used that plug, my IH 404 (I sold it 22 years ago) used the 18mm plug,,
The reach of the plug from my IH 404 was very similar to the reach of a Kohler "K" engine plug.
Considering the application,, the plug for that 404 was probably about the same heat range,,,
Old 05-16-2020, 11:58 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
How would I figure out what exactly die and tap size to use?
Old 05-17-2020, 07:53 AM
cooperino's Avatar
die, yeah Cad, what die should he use??
Old 05-17-2020, 08:33 AM
----just drill it out undersize and re thread.
or use a BS welder.
Old 05-17-2020, 10:32 AM
Haha I have a die and tap set from mac tools. It's a habit of saying oh, die and tap.
Old 05-17-2020, 11:36 AM
I also have access to a aluminium welder at work. Maybe I'll weld it up, drill and tap.
Old 05-17-2020, 03:37 PM
Decided to go ahead and pull the head and have a peek. This what I saw. Flipped head gasket around and found a dark spot. Not sure if its leaking or from hot spot from exhuast What does this mean?
Old 05-17-2020, 06:53 PM
So, I sanded the head with a piece of glass and 180 grit. I used metal ink made just for low and high spots. The head came out nicely. I need to drill and tap for new spark plug.
Old 05-17-2020, 07:29 PM
cooperino's Avatar
Was it burning oil?? That valve being white indicates oil burning. I think your in for a little more than a resurface and gasket
Old 05-17-2020, 07:43 PM
Yeah, it does burn oil. Only a puff when its controlled by the governor
