#41
Gunna put a 3pt on it?
Looks pretty good so far!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#42
Not planning to add a lift. Dump bed is the plan.
Linkage looks like it'll work good.
![]() What you going to use for a box? Building one out of wood, steel?... Keep the pictures coming Frank. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#44
Managed only a couple hours of work on this project today. (Set the base cabinets for the wet bar in the family room this morning so they can come template for the granite.)
Back in the shop after lunch for some mundane stuff like any other Cub at this stage. I rebuilt the carburetor, installed the drive shaft with a new cooling fan. (The drive pin was quite tight in the drive shaft and required heat and a BFH to remove.) Based on the wear of the pin, this cub has not had all that much use. The drive shaft appears original, I don't think the drive pin has ever been out or replaced. Had to drill and tap the air cleaner screw holes as the 10-32 threads were stripped out. Went to 12-24 screws. Spent an hour mounting the engine, carb, coil, condenser, choke and throttle cables and setting the governor. Pretty much together. Painted the starter. Next step will be re-installing the fuel system--tank and supply line--and mounting the starter and muffler. I will need to rig up a battery so I can start and run this thing. Pic-a-rama:
Had another thought/question.
This build is a 109 with a 147's rear end added, and a K301 engine. So it is a 129? The serial number is still a 109, so I tend to want to stick with that, regardless of the engine change. If you could put any model number on this, what would you suggest? Thinking beyond the 109 vs. 129 question...It is a 109T? Does it get a 6x4 logo on it? Let your creative ideas flow here! Tell me how YOU would badge it!
![]() Quote:
![]() Queen Of The Quietlines! ![]() |
#47
I wouldn't put it as 109t cause i automatically thought turbo. Unless your going to turbo it
102 soon to be tiller machine 108 mower 73 plow machine 169 soon to be mower 122x2 now parts machines Parts 129 149 parts 61 "O" 104 job to be determined ![]() ![]() ![]() |
#48
Must be a 6x4 Hydro 244
244 is a result of 147+109-14hp-10hp+12hp = 244 |
#49
My vote is make it a 1029. I like the 6x4 hydro idea too.
#50
Terra-Cub 2612
2=driving axles 6=wheels 12=hp terra-gator_2505_1.jpg On another note, I think it needs lug tires up front too. Just goes with the whole theme. ![]() ____ |
