Old 05-12-2017, 08:02 AM
Do you have the eccentric locking collar on the bearing removed?
(it is the one with the set screw in it, if it is that style of bearing)
Old 05-12-2017, 08:10 AM
Yes George. He got it off.
Old 05-12-2017, 08:23 AM
ok the a little emery cloth to polish the burs/rust off might help.
Ya they are hard to get off, usually a 3 jaw behind the bearing, not flange helps.
Too many of those things on old farm equipment. Ha,LOL!
A cutoff wheel destroying the outer race will free it and the balls.
Then cutting the inner race most of the way through and hitting it with a chisel
will split it is the way to go, or slicing it with a torch if avail as you said earlier.
Old 05-12-2017, 08:24 AM
I agree George.
Like I said, the OP is only missing experience.
Old 05-12-2017, 09:39 AM
john hall's Avatar
Sounds like you have worked on a few Deere combines. Spent 2 hours more than once trying to get them apart. Dremel tool with heavy cut off wheel is your friend.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-12-2017, 11:05 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
That is what I had to do to at least a couple of bearing in my #1 tiller when I took it apart.
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-13-2017, 12:14 AM
jrichards jrichards is offline
Looks like cutting them off is the way to go. I have both a grinder with a cut off wheel as well as a dremel. Either I think will get the job done.
Are these standard bearings or will I need to make a special purchase online to replace them?
Old 05-13-2017, 12:27 AM
You can try the grinder with a cut off, but if the bearing is still recessed, it likely won't reach it. The Dremel will take forever, but will work. Try the chisel.
I already said the bearings were a standard bearing in post #31:
They are a very common flange bearing anyway. Even if you didn't have the number.
Old 05-13-2017, 06:30 AM
You can get cheap ones at most any farm fleet type store. But be advised, there are 2 styles, maybe more. Take one of yours along to match up. You need the ones w/the extended inner race.
Old 05-14-2017, 12:14 AM
Got the bearings off! Used a grinder with a cut off wheel to cut deep enough to use a chisel to do the rest of the work...though I don't think I will be able to bring them into a local tractor supply store as they are pretty unrecognizable now :-).
Now on to taking the tines off. Trying to decide if I should take each blade off the tines separately or try to get the each set of 4 off still connected to the plate
