Old 03-13-2016, 05:37 PM
ab147's Avatar
ab147 ab147 is offline
biggie56, that's what I had planned on doing, got to find a mic that big, I've only got one, and it's max is 1in.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 08-12-2016, 03:59 PM
ab147's Avatar
finally got around to borrowing a mic and a bore gauge, and got these measurements reading top to bottom 90deg. apart.
3.497 3.505
3.503 3.503
3.498 3.498
crank measured 1.497 everywhere I checked it.
Can I use a standard piston and crank or will this have to be bored? I'm not a machinist so some of the measurements may not be 100% but they're close. thanks.
Old 08-12-2016, 04:52 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
3.497 3.505
3.503 3.503
3.498 3.498
I'm no machinist, but I don't think you should bore an engine without having the piston first to allow for variances. So I wouldn't be comfortable just throwing in a new piston into a worn engine.
If you have it apart and have gone this far, I think it's worth the money to get it bored to match a new piston.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-12-2016, 07:17 PM
3.497 3.505
3.503 3.503
3.498 3.498
Ok, listen, I'll lay this out for you. Using a real bore gauge isn't easy. If the gauge hasn't been calibrated for the size of bore you are reading, and if you have never used one before, I am really going to doubt your readings.
Since you have taken the motor this far apart, and since we already know the crank needs ground, NO!! No, you need to bore it, you need to grind the crank and please stop asking for opinions. You have asked at every step what to do, and you always seem to listen to the people who aren't known on here for their engine rebuilding abilities. Just take the block to a shop, pay them to bore it, grind the crank and then you can put it back together. Do it correctly, and you won't regret it. Kits aren't that expensive, if you need guidance where to buy, just ask and we can show you, but stop trying not to rebuild it. JUST DO IT.
You know what.... What do I know. Just run a hone through it, buy a new standard rod, piston and rings and throw it back together. Don't even mess with a gasket kit, you can silicone it back together. It will last as long as the rebuild will.
Old 08-12-2016, 09:41 PM
Merk Merk is offline
I agree with what J-Mech said in the first paragraph. By time the engine is hone it will be close to being if not out of spec. It needs bored and the crank needs ground.
I had a party who didn't want to spend the money to do the work I recommended to do......bore .010, undersize the crank and a new rod. He wanted to "just put rings in it" . He was told it would be an oil burner and possibly down on power in a few years. Three years later he was back complaining I didn't know what was doing and I needed to eat the cost this time for rebuilding his engine. I dug out my sheet that had all the measurements (before and after) from 3 years ago. It had a note on it stating the owner did not want to spend the funds to do what I recommended at that time and his signature on the sheet.
Long story short.....Engine needed bored .020 to get it back in specs. 3 years before .010 would have did the job and he paid for it.
by J-Mech
J-Mech is one of the few on this site who understands what needs done to keep the old IH Cub Cadets running. Hang in there my friend and keep up the good work.
Project Uncle Dick
Cub Cadet 70
Old 08-13-2016, 08:58 AM
dbuck dbuck is offline
Smile K321.
Any person with reasonable common sense, would take J-Mech and Merk's, Dvogtvpe advice. Sure you have to lay out the buck's. My late Father would always told me. Why is it you do not have the time to the job correctly, but you have time to do it over. Think about it.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 08-13-2016, 09:51 AM
Entertaining thread. Just my 2 cents, you can do it the right way or you can jury rig it. Your engine and your $$$. As far as I'm concerned when it comes to old Kohlers we have 3 of the best here on OCC, dvogtvpe, Merk and J-Mech listed in no particular order. I suggest that you take the advice they give you if you want the engine to last.
Now I'll sit back and enjoy the show.
Old 08-13-2016, 10:39 AM
Smile
Your are certainly correct about those three being the best. I do not know how I missed dvogtvpe post. I edited my post to included his name. But their are some people that given advice goes in one ear and out the other.
Old 08-13-2016, 10:56 AM
I just hate to see people spend money only to have to do it over. There is a thread in the general section about just that.
http://www.onlycubcadets.net/forum/s...ad.php?t=45394
