Old 02-16-2014, 05:48 PM
Bob95065 Bob95065 is offline
Bob,
Wow you have taken on a large project. A this point it seems like a lot of items.
I can comment on the trunnion, Yes it will work better if repaired. If you take it apart the corners can be welded and filed smooth to remove the grooves caused by the springs. There is also a quick fix too that just adds two new steel strips ove the grooves.
Looking at your list reminds me of the 147R I did You might look at that post to give you an idea of the road ahead. Yes lots of parts. And I did have to buy a donor tractor to get some things. But I think your tractor is in better condition than the one I drug home.
By the wat some of the early pictures still don't show up but the last ones look fine.
Regards,
Chris
Can I take the trunion out of the pump without dissembling the pump? There is a snap clip on the other end of the shaft. If I remove it can I slide the shaft out of the pump without the swash plate falling? How do you get the shaft and trunion out?
Old 02-16-2014, 08:51 PM
Sugarmaker's Avatar
I have only repaired them in the tractor. Welding small pieces of steel to cover the worn areas. Never took the trunnion off. But a lot of folks have.
Regards
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 02-27-2014, 02:12 PM
Bob,
Regards,
Chris
Can you send me a link to your 147R restore thread?
Old 02-27-2014, 04:12 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=11786
Old 03-16-2014, 08:10 PM
I got some work done on the 1450.
I got some parts in so I started putting it back together. I need to get some parts for the engine before I can continue.
I got the dash and tower on and fixed the controls, wiring and hydraulics. except for the lever. I rebuilt the steering column and closed the gap in the cross member. The gasket between the pump and transmission has been changed and the axle seals have been replaced. The engine cradle has been modified.
Is there a sproil pin that holds the arm on the lift lever?
Old 03-17-2014, 12:36 AM
Thanks for the update and pics!
Old 03-17-2014, 01:21 AM
Do you mean on the rock shaft?
http://www.partstree.com/parts/?lc=c...&dn=0024800031
Old 03-17-2014, 07:03 AM
The 1450 will look great when you are done!
Old 03-17-2014, 09:25 AM
No. I am looking for the pin I need to attach part 4 to part 6 in this diagram:
Tags
#2 tiller, 1000, 1450, california
