#41
![]() Quote:
Make sure you use Heet in the red container. Quote:
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
#42
They made a cold start kit for the 14 and 1650's that was nothing but a clutch in the driveline to disengage the hydro pump for easier cold starts. years ago someone posted some pics of this on another Cub Cadet forum and some one else had an instruction sheet. even on gear drive it makes sense to push the clutch in so you don't have to spin anything in the trans in thick oil.
#43
![]() Quote:
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
#44
Don't all the manual cubs have to be started with the clutch in? My 126 has to be as it's a safety feature....nothing happens when you turn the key and the clutch is out
#45
[QUOTE=Merk;235409]I add the whole container to a 5 galion container. My IH Cub Cadets have a rubber line. Never had a fuel line issue.
Make sure you use Heet in the red container. Ah.....some of the ingredients of the famed "Merkle" Top Secret Fuel Mixture is shared...I've heard of your fuel mixture from a couple of guys in my area and they said that their cubs really like it! ![]() Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
#46
![]() Quote:
My 122 has no wireing for that saftey switch.My 106 has it though but I never start that in the winter,
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains 106-42"deck 1250-44 and 50" decks 147-44"deck 2155-42"snowblower 38"deck, chains,suitcase weights Exmark Quest-zero turn 42"deck 23hp Kawasaki engine |
#47
Erh...yes...they are supposed to be that way, but I'm sure many of them have been modified throughout the years. Both my dad's 125 AND my 147 no longer require the foot pedal down to start.
#48
#49
As found on a different site:
The difference between HEET and ISO-HEET: ISO-HEET (which comes in a red bottle) contains isopropanol while HEET Gas-Line antifreeze (which comes in a yellow bottle) contains methanol. Both products prevent gas line freeze-up hassles but remove water in different ways. Iso-HEET has five times the drying power of regular gas-line antifreeze - you might want to give it a try under extreme cold weather conditions.
-Ryan
#50
I don't want to start a oil war just some info. You can find the cold pour on the oil manufactures site.. I don't remember now however comparing cold pour points a year ago Rotella hd 30 had lower cold pour than many 10w30 engine oils also used oil analysis showed rotella delo to rival and even beat many synthetic oils. Engine oil has come a long way since Kohler made these engines along with operators manual..
1541 (2) 1440 1282 1604 cast rear/transmission (582) 149 1450 (2) JD317 54" blade JD318 Ford 3600 |
