#41
Todd,
I will get some pix to you on wed of mine.
#42
Thanks Lew!
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#43
what year is you 125. Im told , in 67 the engine was a little diffent. in 67 the head bolts have studs on top with 1/2'' spacers that the tins set on. and the heat shield has a bend in it. pre 67 the shield was square.
I have another 125 with the studs and spacers (no pic of the engine) I can get pis of it , if needed. pic of 2 diffrent heat shields
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
#44
Thanks Doug. I'm really confused now. Between you and Lew I don't know what I have.
![]() I believe that the tractor is a 1969, and the engine number is D06(either a 6-5-8) 279. So am I correct in assuming the engine is a 68? Here's a couple pictures of what I got. Thanks for any assistance.
#45
Ill get pics of the other 125 I have.
#46
Todd,
Here is my 125 with the same tins that you have. ![]() There are no studs,just bolts holding the head down.The tin,heat shield,and tank bracket are held on that way. The head is not a low boss like yours. The other picture is the 107 that I am swapping out the smokey 10 hp with a good one. ![]() This has a head like yours,washer,nut,spacer,and then jam nuts hold on the tank and the heat shield. So either you find tins like on my 107 and use bolts and studs,or find a high boss head and use the tins you have.You will need the heat shield too.It also helps support the muffler.The heat shield Doug posted will work also. ![]() There are different locations on these heads for the spark plug.Be sure to get the tins that have the holes in the same spot as yours. ![]() Clear as chocolate? ![]()
#47
Thanks Lew. I can see clearly now
![]() But you never know how my brain don't wrap around things very good. You may still get a call ![]()
#48
Finally got back on project 125.
Been a slacker for to long, lately it's been snow removal along with other things that are out of my control........ so on we go. Yesterday I got to put my torch to the test, or more so, my ability to use it. I couldn't get the exhaust pipe out of the engine, rusted so so bad. I tried the PB for weeks at a time, then put the pipe wrench on it, with no luck. Talked with my dealer buddy and said to heat the pipe till it's red hot and let it cool. Then put the pipe wrench on and it will come right out. It worked! What he told me, was by letting it cool completely I wouldn't hurt the threads in the engine, works for me. Also need to do some work to the pto clutch.
#49
Thanks for the update and pics, Todd!
#50
Thanks for the update Todd, Glad to see the hot wrench is earning it's keep.
