Old 06-23-2012, 11:29 PM
Your muffler came out great.
Yes it did!
Old 06-24-2012, 12:50 AM
cjet69's Avatar
cjet69 cjet69 is offline
Yes it did!
Thanks guy's. Can't wait to get it installed.
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 06-26-2012, 05:50 PM
cjet69's Avatar
Picked up an exhaust elbow from a local guy today. He had a parts engine out of a 1450. It only took a little heat to free it up. I should be able to get the exhaust system installed now.
CC 124
CC 1220
#2 Cart
Old 06-26-2012, 09:50 PM
Glad you got the part, you were looking for.
Old 07-29-2012, 02:54 PM
cjet69's Avatar
I decided it was time to find out why the rear end is leaking around a couple of the rear cover bolts. This is what I expected, but didn't want to find. Anyway , it gives me an excuse to try out some new wire in the MIG welder thats for cast iron. I also found why this happened. PO had 2 shouldered bolts in those holes. Looks like the shoulder got to the casting and split it.
CC 124
CC 1220
#2 Cart
Old 07-29-2012, 10:54 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Originally Posted by cjet69 View Post
I took the 1450 back to the orchard and did some mowing. Work's pretty good. Lot's of power and the old Kohler really smoothed out at the higher throttle setting. I didn't get any pic's with the tractor, but here is the orchard and the roadway thru the field to it.
Really nice work. You'll get the bugs worked out soon enough. I believe you may have already caught the fever.
Under load it should run it at full throttle even if it don't seem to need it.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 07-30-2012, 02:22 PM
Yikes the rear looks bad to me.
Old 07-30-2012, 04:37 PM
cjet69's Avatar
Started prepping for the weld. When I started to v out for the weld the whole side of the bolt boss fell out. I was worried that I couldn't find the small piece that had broke out of the upper hole, but on inspection I found two small pieces stuck to the rear cover gasket.
CC 124
CC 1220
#2 Cart
Old 07-30-2012, 04:41 PM
cjet69's Avatar
It should repair quite easily. knock on wood. I'll keep updating as this goes along.
CC 124
CC 1220
#2 Cart
