Old 03-07-2012, 08:58 PM
Originally Posted by Jibtorquerz1 View Post
I have a 61 original my dad bought in 78, its almost finished, the only thing i can't find is a throttle lever and cable. And also where in the heck do you find the serial number. I'm new to this forum deal sorry if i'm asking in the wrong area. I'll get some pics soon as I figure out how. It has been great fun restoring and seeing how many other people feel the same about some little ole tractor. Thanks very much Jibtorquer
This will help you with the serial number location:
http://cubfaq.com/serialnumbers.html
Contact our sponsors at the top of the page for help with the throttle lever and cable needs.
Old 03-07-2012, 09:09 PM
EricR's Avatar
EricR EricR is offline
Yep, Jibtorquerz1, contact the sponsors and they can help you out, as I needed the throttle cable and handle and have one coming so they are out there. And also welcome the the site.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-07-2012, 09:45 PM
PaulS's Avatar
PaulS PaulS is offline
Welcome to the site. If you have questions someone here can help you. EricR is my son so he and I are doing this fix em up in honor of my dad who had an original.
Old 03-09-2012, 09:19 AM
PaulS's Avatar
Eric received a package yesterday. It was from Patton Acres. In it was the throttle and cable for the "O" and a nearly impossible to find piece for the clutch. We dug in and mounted the throttle and cable on the tractor. Since I had already changed the oil and cleaned the air filter we just had to fire it up. As you may recall the clutch has been removed. It fired right up but we still had a rattly noise. We finally found the source. The muffler is one of those round screw on types and looks fairly good on the outside but apparently the insides are just banging around inside and making the odd rattling noise. Oh well we are considering a pipe for the exhaust anyway but it was a relief to find it was something so easily taken care of.
Old 03-11-2012, 04:35 PM
PaulS's Avatar
A couple more boxes arrived Friday. We now have just about all we need to totally rebuild the clutch and the operating parts for it. We did discover that we cannot find spirol pins locally or have not found a dealer that has any. We ordered them from Cub Cadet as they were available through them. When they get here we will take the clutch assembly apart and do a rebuild. We also received the parts for the rear end, i.e. rear gasket, oil seals, and bushings so that comes next. We did remove the rear plate to drain the tranny fluid and although no watr was present that stuff was thick and yellow in color. It should have been at least motor oil colored or dark at least to my estimation.
Old 03-13-2012, 07:55 AM
PaulS's Avatar
Last night we took the S/G off and it is making some not so S/G noises. Gotta get that on line for rebuild too. I swear the POs did not have any grease or oil to keep bearings lubed.
Old 03-13-2012, 11:11 PM
I was able to get my spirol pins from my local bolt supply house. I paid .47 each. Getting the parts in is lots of fun!
Old 03-14-2012, 02:40 PM
PaulS's Avatar
Duke I wish we had a local supplier of such things but a phone search of local folks in a similar business did not produce any of the spirol pins of the correct size we need. In desparation I ordered them from the cadet site. I will not give up on a local supplier but just have not found one yet. There is a Surplus city about 35 miles away that I plan to look through when I am near there.
Old 03-14-2012, 07:12 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Any Fastenal stores nearby?
Farm or tractor places might be a source too!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-14-2012, 08:21 PM
PaulS's Avatar
I do not recall any Fastenol stores but we do have a tractor supply local and I never thought of them. Duh.
