#41
Nice cubs! Good luck with them.
#42
nice 782. the motor swap should go good for yah. mine has a 18hp B&S.
#43
I'm ready to power-up. Disassembeled, cleaned, inspected, painted and put back together. I still have to paint the tins. DSCF1119.jpg
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
#44
Putting a Briggs V twin in these is easy. It's all bolt in. My 1210 now has a 16hp Briggs out of a 2160. used the muffler from a 1640 and the motor plate from a 1440.
#45
Looking forward to your update on the Vanguard in your 782!
#46
yesmar74
A couple pics of what my re-power looks like. It has the complete driveline out of a 1440 so this one is a total bolt in swap. You may need to play with the drive shaft but no big deal. Like I said the engine came from a 300 hour 2160 complete with the drive shaft adapter and the PTO cost me $300 for the tractor. The 1641 muffler came from Patton, cool guy. The 1440 was a swap for a plow I had so for me it was cheap deal. If 16HP is enough power look around for a 2160 on C list. They go cheap because the transmissons are junk. Hope this is of some help. |
#47
Gary, It was good to meet you and your son today. I hope looking at my 18hp B&S engine swap helped you out.
It'll be back apart in 2 months if you need better pics.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
#48
Thanks Doug, We got some good ideas from looking at your 582. It seems the biggest issue is we're going to have to find or fab a flywheel coupler to connect the driveshaft. All else seems pretty straight forward. We pulled the screen off the flywheel when we got home and it looks very doable. I hope to have it swapped before 2 months but thanks for letting me know. Sure glad to have met you, maybe see you at plow day sometime.
#49
Gary
The adapter is Cub part # 719-3096 you also need pin # 711-3330 and two 5/16 X 1 3/4" bolts. This is for a Cub 2160 from the Cub parts web site. The Cub parts are about $38.00 & shipping Sam |
#50
Thanks Sam, I checked it out and that looks possible. Although the driveshaft end is not the same on a 782, it looks like the adapter could be made to fit. And if not the picture gives me some idea of what the part looks like if we decide to fab one.
