Old 04-19-2011, 07:59 PM
rpage83 rpage83 is offline
CC1450, only 10 bucks for the 55 gal drum, five to seven t post laying around and 12 bucks for the lye product. It has help emensly in removing rust and paint. I have used a wire brush and or wheel to remove the stubborn paint. Overall, very impressed. Heres a closeup pic of that tower after some cleaning and primer.
Also got the frame soaking. Will take a just after bath shot. I promise.
ran another t-post as close to the center as possible.
Here is one shot of the engine shrowding.
Ooooh the bubbles.
Old 04-19-2011, 08:03 PM
Default Got a painting.
Good to finally see some yellow on some parts.
Will be working on the red...I mean yellow engins. (she runs just fine!!)
And odds and ends. Need a latter setup like Matts, on his cub page.
Old 04-19-2011, 08:47 PM
CC1450's Avatar
CC1450 CC1450 is offline
could you use a steel drum as the tank and hook the + up to the drum itself? Just curious, I have a steel 55 gallon drum here somewhere.
Those parts are coming out top notch. It's amazing what you learn around here just looking at the threads.
Old 04-19-2011, 09:25 PM
Not sure if you could use a steel drum since your pos is the sacrificial anode. Maybe you could try, but do NOT touch it unless its disconnected. I have seen rebar, a welded ring that sat in the bottom and some just use a old lawn mower blade. I guess its up to the user. Let us know how it works out if you decide to do it.
Old 04-19-2011, 10:06 PM
What do you do with the mix when your done with it?
Old 04-19-2011, 10:32 PM
Awesome job! Thanks for the pics!
Old 04-20-2011, 12:28 AM
Methos,
I plan on doing three tractors this summer, so I wont know for sure what I will be doing with it. I do know that we find yard tools and other left outside items that could use a good soaking every now and then.
Old 04-20-2011, 10:40 AM
CC1450's Avatar
The tanks remind me of the "dip" in the movie who framed roger rabbit.
I would ask around about disposal when the time comes. With the 55 gals of water diluting the drain cleaner so much I imagine you could just dump it down the toilet 5 gals at a time, then bag and toss any sediment/solids left in the bottom.
Old 04-20-2011, 12:10 PM
That is what I was thinking. Like I mentioned, I have two other tractors to do this summer and I have a buddy in the Haz Mat team around here. I will ask him later. Im guessing that with drain cleaner and water, sould be fine. Then as you mentioned, I could filter the remaining solids and possibly dry them, then throw it away.
I read some info about zinc coating on Matts webpage. Not sure if I want to play with different types of acid to get shinny bolts??????
Old 04-20-2011, 12:13 PM
Methos,
I love how this works but being on a septic system I'm worried about the waste once I would be done with it. Not looking forward to crashing my septic system. Looking forward to any info on this.
