Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 07-09-2020, 10:12 PM
TomRom's Avatar
TomRom TomRom is offline
It won't hurt to put in the new points, but, as a quick check before you do, run some fine sandpaper between the contacts first. Make sure there closed by hand rotating the engine, insert paper between the contacts, let points apply pressure to paper while you pull thru. Make sure both contacts are clean and shiny.
I once had what I was convinced was some carb problems, and turned out to be bad points...
IHCC - 122, 125 x2, 127, 108 x2, 129, 149 x2, 1200, 1250, 1650 x2. SEARS - Six Speed Suburban 10HP, Quick Speed Change Suburban 10HP, Six Speed GT18 Twin. ECONOMY - Country Squire. CASE - 580B CK tlb. That's it for the 4 wheel ones....
