#31
I've only rebuilt one cub, my 1282, due to sentimental value. Sadly it's a lot more economical to get a parts engine. In the case of my 1711, I had nothing into it, and went with a Command (that paid for itself). Certainly better to keep some things original
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#32
I had some vacation time off from work. So, it was time to get this 1450 project finished. As I mentioned before, this tractor had all of the Quiet Line afflictions including a tired engine. The engine was the easiest part of this project. You can see pics about the engine in previous pics. I had to replace the air duct housing along with an aftermarket muffler and a "muffler crutch". The muffler is heavier than the OEM but mounts easily and is very quiet! Since this was a late model 1450, I cut off the excess exhaust pipe. ( Does not protrude through the grill)
I installed new rag joints and hardware but broke my own rule...I did not install new couplers and drive shaft. I started the tractor....engine runs great but tractor had severe vibration! So, dang it all I have to change out the worn parts. Fortunately, I had a new shaft and couplers on hand...changed them out. Much smoother....for a Quiet Line. Finished assembling the unit and installed the mower deck. The unit will be a worker and not show piece. It needs a bath and it will get it after I mow some grass with it.
Queen Of The Quietlines!
#33
I also installed a new field coil since the old one beyond repair.
The completed tractor!
#34
That's so cool! I love seeing these tractors still going strong.
My 1250 needs the cork gasket replaced. Can it be done without splitting the tractor or am I just dreaming?
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
#35
Hi Randy. Yes you can replace the cork gasket without splitting the tractor. However, the drive line should be removed to gain access...you may open a Pandora's box by taking an old Quiet Line drive line apart. Remember that little pump is heavy. BTW, I did change the cork gasket on the 1450 without splitting the tractor.
#36
#37
I have replacement flex couplers that I'm going to replace at the same time and If I can get the motor mount mod welded on a spare pair of mount brackets i bought and borrow an engine lift to upgrade that and the the oil pan. The motor mount are sagging and I figured its best to "fix" the whole drivetrain and not run with it partially redone.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck |
#38
#39
what is the "swivel bearing"? I'm looking at the parts diagram and don't see the normal driveshaft in the assemblies, just the clutch dissconnect option.
#40
There is one on the engine side where the front flex disc mounts and one on the hydro input shaft coupler. https://ccspecialties.org/pics/flangelarge.jpg https://ccspecialties.org/pics/919-3027coupling.jpg
