Old 01-15-2019, 06:23 PM
twoton twoton is offline
I hate easy outs.
Old 01-15-2019, 08:17 PM
Originally Posted by twoton View Post
I hate easy outs.
Agreed. If it doesn’t budge right away it will end up snapping. I deal with a lot of rusted allens at my job and have found that if most of the ways mentioned (not in that order) are unsuccessful, my go to last resort before drilling it out is pounding a torqxe socket into the Allen and try. The many teeth of the bit grip and bite into the Allen and also the shock of hitting it in there will sometimes help loosen it. If even more stubborn I put a 1/4 or 3/8 breaker bar on it (depending on size) and hit on the breaker bar while applying pressure to loosen. Using an impact driver works as well but you can’t “feel” what you’re doing as much because the impact/breaking motion is only determined by how hard you hit it.
Let us know what works
Old 01-15-2019, 09:44 PM
That was my 1st thought also, Tom
I'd go with a nut that will screw onto what's left of the set screw threads you can see in his picture, I believe they are 1/4 NC
The welding will induce heat into the screw ad surrounding hub, and will probably do the trick after waiting a few moments before attempting removal.
5/16-18 NC
Turn the nut on what's left of the set screw, mig weld it on and then try to turn it out.
Old 01-16-2019, 11:44 PM
rsshallop rsshallop is offline
Everyone, Thank you for your input, It's really great to have such support. The set screw is still stuck after many attempts using PB-Blaster, hammering it with a pin punch and using a new hex key after applying heat. The nib on the end of the set screw is definitely compromised now as my last attempt involved applying heat from my propane torch and then dremeling a slot for a flat head screwdriver into it. At this point, I'm not going to try mig welding. I'm sure this approach is solid, but I've never mig welded before and the engine is fairly heavy to be carting out to someone who can do the welding. Instead, I'm looking at purchasing Irwin Industrial Tool 11119 - Screw extractor with matching left hand cobalt bits. They look to be of good quality for working on hard steel and are available up here in Canada (not everything is). I'll let you how this ends up once I get these extractors and L/H bits.
Old 01-17-2019, 10:31 AM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
Originally Posted by rsshallop View Post
At this point, I'm not going to try mig welding. I'm sure this approach is solid, but I've never mig welded before...
I'm wondering where the point is in the progression of yellow fever it is that one would be scrambling through the circulars, looking for that holiday 25% off coupon with an excuse to run to Harbor Freight (or in this case Princess Auto), to pick up that cheap 110v wire feed machine that's always on sale and learn to weld?
I learned welding at a trade school, but to be frank, YouTube is pretty awesome when it comes to tutorials. You can become quite proficient in the time it takes to burn through 1/2 a roll of wire. Speaking of which, if you buy the cheap HF wire feed, throw the wire that comes with it, buy name brand wire, and never buy wire from HF again. It's a pretty decent little machine for puttering. I have a steel plate with a vise on the corner of my workbench, and the dented open box special welder I hesitated to buy has proved to become one of my favorite tools in the shop.
Clarification - the $89.99 special is not a MIG welder, it's very similar but uses flux core welding wire in place of a shielding gas. Yes, a real nice MIG would be the proper tool, but I see little point in splitting hairs, they'll both heat the screw and stick a nut to the top of it. 110v wire feed is a good choice for home hobbyists that don't have a 220v outlet in the garage or any other need/desire to own more substantial equipment.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 01-17-2019, 02:25 PM
Hello, Does anyone have any ideas on how to remove the set screw that locks the pulley onto the crankshaft on my cub cadet 108 (stock engine). It won't budge and I am pretty sure i have stripped the opening that the hex key goes into. I have also tried removing it by chiseling the top of the screw counter clockwise, but the screw still won't budge. Below is a picture of the screw in it's current state. I don't want to go any further without some input... Lots of WD40 has been applied over the last couple of weeks. Thanks.
Didja get the other one out or is it stuck also?
Old 01-17-2019, 03:53 PM
It will prolly drill easier now that you have negated the heat treatment it once had with the application of heat from a propane torch
I've had some difficult jobs, but once you heat them up cherry red with a act/oxy torch, they usually loosen.
@ this point I think you are going to have drill this one out.
The pix makes it look shallow, if so, that is in your favor.
I have some carbide bits I keep for special jobs but they are easily shattered,
so caution is paramount and not to be used in a hand held drill motor.
A good jobbers drill used slowly with lube, and pushed hard, should drill it.
At least you have a good center point to get it started straight.
Do as you like,but I don't like easy-outs
They are for different situations.
If the bolt, stud or setscrew was stubborn enough to break off/strip, an easy out will get you in more trouble when it breaks off in da hole, and do remember they are tapered so it expands the screw making a better grip on the threads.
That Said:
I'd try one more chance of heating it up, & driving a torex bit in it while hot/heating,
and gripping the bit with a vice grip and working it both BOTH directions,while hot.
if it moves either way, just a mere smidgen, it will eventually come out.
If it moves ever so little, stop and go the other direction,
you are trying to work it free, not muscle it out
Also, bees wax applied will act as a lube when hot.
Just be aware bees wax will flare up (ignite) so don't piss yer panties
Old 01-17-2019, 06:05 PM
I'm following your advise ol'George. I'll proceed as you have laid out and keep mindful of not wetting myself in the process. Thanks.
Old 01-18-2019, 09:55 PM
Default got it out
I can't believe it. Thank you for your superb guidance.
Old 01-18-2019, 10:32 PM
sawdustdad's Avatar
Yeah!! Glad you got it out!
