#31
Arrogance because you know what you're talking about? I could have gone without all of that nonsense, and you could have skipped to your last response which was informative, despite the arrogance yet again. J-mech: you can't increase the compression enough from milling alone to justify using 93 octane Pray: ok, I guess the compression is so low in stock form that milling won't increase enough to get to 93? J-mech: correct, you can mill .0xxx and run xx fuel, with xx carb/jets to start Pray: thank you for your expertise, afterall, I came here to seek info from those with experience. Or J-mechs last post, very informative Pray: so the m18 simply is not worth messing with for the reasons you listed? J-mech: yep, unless you want to throw a lot of money at a custom setup. Pray: thanks! That simple |
#32
Im surprised you had not asked if doing this would hurt your "work" machine that you mow 4 acres with. Yes it will. Any mechanic knows compression equals heat. These engines really hate heat.
#33
Ok,
If you wanna mill .040 max off the heads, have at it, but check valve spacing first. If you have build experience, you know compression increase gives you power increase from zero grunt rpm to what ever you feel comfortable winding it too. I'd stay under 4000. You will still be able to run pump gas el cheapo,-- the throttle response will be a tad"snappier" If you put it on a dyno you will say, hell it wasn't worth the cost of the head gaskets. But you will feel warm & fuzzy. It took a lot to make power from a flathead back in the day. One reason why the Chrysler "Hemi fire dome" was so coveted, till the Small block chevy took over, then every body jumped on the band wagon. I have to laugh, remembering every weekend @ Detroit dragway when some engineer tried his idea of a better mouse trap. I was lucky enough to be witness to it all.
#34
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#35
These old tractor mower are very good.... but nothing mows like a ZTR. Much higher blade tip speed, much better deck, better stability, ability to turn on a dime.... all equal much faster mowing times. It's silly to think that a ZTR wouldn't save time. Not willing to justify the cost, well that is understandable. Simply not wanting one... also understandable. But saying it wouldn't save any time is kind of an ignorant statement. Even a good ZTR with a smaller deck would mow circles around a tractor mower. |
#36
What we're all trying to say is "Welcome to the 2nd friendliest Cub Cadet forum on the web!"
he he.....
Rusty 149 project with: QA42 snow thrower 38" deck Barn fresh 1811 with: 44c mowing deck QA42A snow thrower 42" snow blade |
#37
![]() Once guys realize that it’s not worth it and their feelings are healed up, it’s all good. You can take it however you want, but we never lead people to do things that we have seen/tried and failed. We aren’t mindless cheerleaders here.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
#38
I think it is time for the OP to do what he wants. He has been given a lot of information. He can do what ever he likes with it. After all, it is his information, his time, his money, and his Engine/Tractor.
#39
Yep, I got my ass kicked to get it, but I can't say I didn't get what I came for.
#40
