Closed Thread
Old 08-18-2017, 07:46 PM
Originally Posted by sir_lancealot View Post
The only problem is the VR898 does not cross to the original V/R number. Only the VR896 does. The 898 crosses to these numbers: 1118779, 1118987, 1118999,& D646. The 896 crosses to these numbers: 1118988 & D655.
So, you need to use the VR896 because it is the correct one.
The VR898 is correct for the Original, 70, and 100 models only. I believe it is because they have the push button start, so the 898 is different internally to handle that.
The VR is not related with the push button start in any way. The difference is with the "L" terminal, which I believe, if you can find some of the original installation instructions, is where IH wanted you to get power for the optional lights on the 70/100. Or from the ignition switch, where it was wired anyway.
The VR896 is a direct cross for all the VR's on any of the Cub Cadets that used a S/G set up.
Lance, where did you get the interchange list you provided? I can't find a listing of what the Napa VR's replace.
  #32
Old 08-18-2017, 08:14 PM
The VR898 also can be used on a positive grounded system. I think it was just the common V/R used during that era. Which I think the VR896SB can be used on pos or neg grounded systems too, but I'm not 100%.
I found it with my Google-fu. I'd have to go back and see if I can locate it again.
  #33
Old 08-18-2017, 08:45 PM
Here is the bottom line.
It is your tractor, it is your time, it is your money. You can do as you see fit.
All we can do is point you in the right direction. If you don't like our advice, so be it.
Closed Thread
