Old 06-16-2017, 03:38 PM
TommyK's Avatar
TommyK TommyK is offline
Originally Posted by Edmonds View Post
So, from what I've gathered, I need to put an insulator on the wires that aren't insulated? @TommyK @Ol' George I have seen the carbon brushes, but they seem to be worn down, would that be a problem?
You need to put an insulator on the stud that doesn't have one. You referred to it as terminal A. You can see one has one,it looks like a white washer, and the other doesn't. Can you take a better picture to show the brushes?
Old 06-16-2017, 04:01 PM
Edmonds's Avatar
Edmonds Edmonds is offline
Here you go, as I said, the brushes are worn down.
Old 06-16-2017, 04:04 PM
Bamafan Bamafan is offline
Inactive Member
using your pic these are the parts they are talking about. #1 is the insulator with out it the generator will short out. #2 is the brushes, from what I can tell by the pic it is in need of set.
[B]Larry[/B]
Old 06-16-2017, 04:13 PM
Inactive Member
Actually those brushes look pretty good, but if it were me I would put a new set in it. I think your main problem is the insulator. Just hope you didn't fry the coils.
[B]Larry[/B]
Old 06-16-2017, 04:17 PM
TommyK's Avatar
You definitely need an insulator. The brushes in mine look like yours, and my 108 runs fine. Wouldn't hurt to replace those though. Were the brushes in the holders, or dangling free? When I bought my 108, the PO had been messing with the SG and one of the brushes was dangling free, so the tractor would not charge.
If that insulator bushing was missing, it either broke into pieces or the PO was messing with the generator.
Old 06-16-2017, 04:18 PM
Edmonds's Avatar
Inexperience talking again, but a new set of what? Is should be able to take care of the insulator.
Old 06-16-2017, 04:24 PM
Edmonds's Avatar
They were in place until I took the starter apart, I got the left one back but I'm not sure where the one on the right goes.
Old 06-16-2017, 04:45 PM
Inactive Member
I'm referring to a set of brushes.
[B]Larry[/B]
Old 06-16-2017, 04:50 PM
TommyK's Avatar
The brushes go in the same way on either side, so if you got the left one in you should be able to put the right one back in. Just make sure when you put it back together they're in correctly.
Old 06-17-2017, 09:14 AM
Edmonds's Avatar
I'm considering buying a new starter altogether, what would be the best place to get one?
