Old 05-26-2017, 10:22 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Originally Posted by TOPDOWNRESTO View Post
Also and lastly for my 1650 I could use the measurements for the placement of front hydro outlet holes as I will need to do that . I have access inside or out as engine and cradle are out still.
thanks for your help
Carroll
I'll get that for you next week when I return home.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 06-04-2017, 06:49 PM
gsomersjr's Avatar
Default Measurements
Here's the measurements to locate the front holes for the hydraulic ports. I'm just okay at measuring and even worse at drawing so....
Old 06-05-2017, 08:24 AM
TOPDOWNRESTO TOPDOWNRESTO is offline
Got it, thanks Gary !
' 68 125 '75 1650 dual stick
Old 06-07-2017, 09:35 PM
Originally Posted by gsomersjr View Post
The handle I have is broken so I'm adding both pieces to get the total measurement. I've attached a pic of an unbroken handle also.
The center smooth section is 4 11/16 long, .40 OD
The good end has 1" of 3/8-16 threads
The broken end has (approx.) 1.75" of 3/8-16 threads
Total length is 7.5" including the machined tip that acts as a lock on the horizontal shaft.
I'm not a machinist so these measurements are just "pretty close"
I corrected the thread size in your reply. Please go back in your reply and change them from 24 threads per inch to 16 threads per inch.
I have to make another shaft
