Old 08-29-2016, 09:36 AM
Wayne Wayne is offline
I'm still stuck. Since I damaged both the needle and jet/nozzle I bought an aftermarket carb that has a POS needle. I still have the same problem as ever. Gas to carb, gas runs out of carb, but spark plug is dry and no start. But if the main needle isn't involved in starting I don't knmow what to do. I'm ready to dump this thing in the lake.
Cub Cadet 2166
Old 08-29-2016, 10:27 AM
budscub's Avatar
budscub budscub is offline
Default Is the fuel cap on when this happens.
Just a quick question, from the last post. You said you put an new aftermarket carb on it and it still leaks fuel from the carb. This is just a guess, but does it do this without the gas cap on? Sounds like maybe you are pressuring the fuel to the point of over coming the needle seat. Leave the cap off and let it sit to see if it still leaks. If the cap is not venting correctly, it is possible the the tank is building pressure and foring fuel by the valve.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 08-29-2016, 01:02 PM
What I mean is the carb spits fuel out when I crank it. Usually its on the last crank just as I release the ignition key and I see a pretty good splash of fuel spray out. But the plug is always dry.
Cub Cadet 2166
Old 08-29-2016, 04:58 PM
cubs-n-bxrs's Avatar
One other thing I can think of right off the top of my head is the valves. If the intake valve is not closing all the way on the compression stroke it will do the same thing it will be pushing air/fuel mixture back out of the carb. Something to check.
Old 08-29-2016, 06:11 PM
X2 for possible stuck intake valve causing your issue.
Old 08-29-2016, 07:48 PM
Sounds like a good idea. Any instructions anywhere? I've only done valve adjustments once, on my old Kawasaki.
Cub Cadet 2166
Old 08-29-2016, 07:50 PM
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Old 08-29-2016, 08:42 PM
I've got the breather cover off, but its not obvious to me how to get the rest of the breather assembly off. The one in the service manual illustration looks rather different than mine. There is a thin plate apparently mounted to the stud but I can't see how its mounted or how to remove it.
Cub Cadet 2166
Old 08-29-2016, 09:40 PM
Slides right off the stud. There's a rubber spacer in front of it that will come off the stud. Just remember the order or everything and orientation plus the oil drain hole. Everything slides out behind the cover individually
Old 08-29-2016, 10:36 PM
Yup, thanks. It all came out as one piece though. At any rate I'm down to the tappets now and I just need to find TDC. better wait till morning for that though, or I'll find a way to screw it up
Cub Cadet 2166
