Old 05-21-2016, 08:03 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Looks great Jeff.
Can't wait to get them in. Thanks for the FAST turnaround!!
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 05-21-2016, 03:11 PM
bocephus1991's Avatar
Please double, triple check you clutch adj. do not get it too tight. I had mine to tight and screwed everything up!
Brian
Old 05-21-2016, 04:56 PM
vr4Legacy's Avatar
I just saw your post... OUCH!
I will be sure to quadruple check it. That's the last thing I need.
The adjustment seems pretty straightforward. What do you think you did wrong?
-Jason
Old 05-21-2016, 05:22 PM
Just adj to tight. I had about 1/4-3/8 of threads showing when I adjusted it.
Brian
Old 05-23-2016, 09:25 PM
vr4Legacy's Avatar
Got the solid mounts today. They look great Jeff, super quick delivery too!
Now I just need a free evening with no rain..
Thanks everyone for the advice and help. Hopefully I'll get to try out the Cub this weekend
-Jason
Old 05-28-2016, 12:35 PM
vr4Legacy's Avatar
Put the solid mounts in and got the right belt on. Took the 1200 out today and finally did some mowing with it. It did GREAT until the adjusting nut fell off the clutch rod
Finally the mower gods decided to shine upon me though because it was sitting on the mower deck. I couldn't believe it. I'm going to get a lock nut to put on this time. I think I might have had it a little too loose. Any other suggestions to avoid the nut falling off? If I can fit a second nut I plan on doing that too. Maybe some locktite?
-Jason
Old 05-28-2016, 01:51 PM
Did you have a nylock nut on there? That or two thin nuts so you can jam nut them.
Brian
Old 05-28-2016, 01:58 PM
vr4Legacy's Avatar
I used the old nut. It looks like it may have been a lock nut at one time. I'm going to get a new lock nut and try that out.
I have 3/8 -24 for the size. Does that sound right?
-Jason
Old 05-28-2016, 09:28 PM
Bob95065 Bob95065 is offline
I used the old nut on my 1000 because it looked like it was spherical where it contacted the clutch throw out arm. Mine felt like it lost the locking feature so I put a second hex nut behind it. I haven't had a problem.
Old 05-29-2016, 01:05 PM
vr4Legacy's Avatar
Put a new lock nut on and everything went great. Until.... it just stopped moving. Apparently the roll pin came out of the back of the driveshaft... lesson learned. Don't re-use roll pins. I foolishly reused it when I replaced the drive train. At least it was an easy fix.
-Jason
