Old 07-08-2016, 09:47 PM
Dirty Steve's Avatar
Great job. I wish I had courage and knowhow to put additional hydraulics on my tractors.
Old 07-13-2016, 08:26 PM
Workinprogress Workinprogress is offline
More parts arrived.
Purchased headlight and upper grill off eBay.
New Ignition switch, fuse holders, pto switch, seat switch, side panel spring.
Picked up two bag of spiral pins (heavy duty and extra heavy duty).
Have lower grill on the way.
Hooked electrical up and everything tested fine!!
Getting closer!
At least three more orders to make but will have to wait.
New seat
hydraulic quick connects and hoses for front outlet.
Decals
Old 07-13-2016, 10:16 PM
RedOnes's Avatar
RedOnes RedOnes is offline
I`ve got ADD, but I can appreciate someone who takes time to do a job right ..
Frank
IH 982 , 3 point
CCC 782
Old 07-23-2016, 10:42 AM
Hydraulic lines and quick connectors installed.
This will be my first cub with front and rear quick connectors. I am sensing a hydraulic dump trailer in my future but I have to build the 3 pt for this tractor first. Tees went on easy and having the hydraulic lines built with 90 degree ends made the installation nice and clean. Next steps to install engine, firewall and gas tank. At that point should be able to fire the tractor up and check for hydraulic leaks and set the neutral on the pump.
Have a little paint touch up on hood and side panels.
Old 07-23-2016, 06:13 PM
RedOnes's Avatar
Lookin good ...alright ...the engine ...
Frank
IH 982 , 3 point
CCC 782
Old 08-03-2016, 09:53 PM
Slowing moving forward.
Engine mounting spacers - Since I picked up this tractor as a engineless I just realized I was missing the engine spacers. Went to local hardware store and picked up 4 shaft collars for 7/16 shaft. They ran $2 each and had a thickness of 0.444. It actually worked very well. I put bolts through the base plate and locked them into position with the shaft collar. Lowered the engine down and tightened everything down.
Old 08-03-2016, 10:03 PM
Dropped engine into tractor and hooked up driveshaft. Went to mount gas tank but hydraulic lines were in the way. I had to rearrange the fittings to the front and rear ports. Basically I had to rotate the tees to clear the gas tank.
Old 08-03-2016, 10:14 PM
Thanks for the update and pics!
Old 08-05-2016, 08:17 PM
Fired engine up and took the 782 for a walk around the yard. First time I have ever seen it move under it own power!
No leaks on hydraulic lines. Pump sounds good.
Old 08-05-2016, 10:13 PM
Great news!
