#31
The disk does pull generally easy for the most part. I do have the rear gangs set out to be 54" wide and it does great. My good friend built my crumbler, I had him build it 6 foot wide that way when turning around on end rows the crumbler is wide enough to take out tire tracks like the big farm crumblers do. The best thing is I don't need to set weight on disk anymore because the weight of crumbler pulls the disk down into ground and it penetrates the same as if I had the 75 lbs sandbag on it like I did last year before I had crumbler. I did put 16 new blades on my Brinly disk when I went thru and painted it. The factory blades from Brinly are 11" and I put new 12" blades on it from Agri Supply.
Cub Cadets: 582, 682, mini 5288 and 5488 Case International 235 compact Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank Living a dream one row at a time |
#32
Do the A/S ones work better? |
#33
#34
![]() That's what I wanted to hear!
#35
#36
That's serious work! That front grille is simply amazing. We never know what CC had in mind for the 82 series, but I'm sure if they look close to what you did they sold them like cup cakes!
"Bravo"
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#37
#38
ok now heres the real question, how much would it cost to have one made?
#39
I will ask my buddy who helped make it, he has tossed the idea around to build them if people wanted to buy them. I will see if he has a general price in mind and let you know.
