Old 05-13-2015, 04:09 AM
Originally Posted by twingard View Post
is there a possibility that this is a bad coil? and nothing to do with the carb...I've had a couple ppl mention bad coil now...any opinions?
Your the one who took us on the whole carb ride.
Sure.... it could be a coil. Along with a list of other things. YOU have to find which system is the problem child. I don't think you wasted your time working on the carb though.
Old 05-13-2015, 06:50 PM
twingard twingard is offline
I aint blamin anyone bout the carb that's what I thought it was all along..sorry bout takin ya on a "ride".....never expected anyone to be able to tell me this is your problem 100%...just was lookin for opinions sorry I wasted your time..take care
Old 05-13-2015, 07:21 PM
I think you misunderstood what I meant. I meant, you asked questions about your carb, so we answered. Now you ask if it could be a coil. Yes, it could. You didn't ask how to diagnose the problem, so we assumed that you knew the carb was the issue. Do you want us to help you diagnose it? You need to ask more specific questions. There are several things that can cause the issue you are having.
Old 05-13-2015, 07:59 PM
So tell the OP what could cause his problems, lets not turn this into a major issue. Obviously if the OP knew what the problem was he would not have even bothered to post.
Old 05-15-2015, 10:59 PM
well I apologize for not askin more specific questions..my bad.....and yes could use some help diagnosing the problem, right now I know that I am only getting spark to the left spark plug wire and nothing to the right plug wire this is when motor is hot or cold but it will still fire and run, it does not sound rough as I would think it would only being on one cylinder but it is much more quiet and flatter sounding then my 1810.....I have taken all the heat shields off and gonna get ready to pull motor this weekend...so any help diagnosing the problem and suggestions on what might be goin on is appreciated
Old 05-16-2015, 12:13 AM
Okay, I missed something someplace along the line.
Why are you pulling the engine? Kind of hard to diagnose problems with a non running engine.
Old 05-16-2015, 01:00 AM
engine does run...but just no fire to right spark plug wire...so Im thinkin ignition coil
ps. I shouldn't of said pull the motor...just goin to move it forward to get to ignition coil is more like it...am I jumpin the gun as far as it bein a bad coil?
Old 05-16-2015, 07:28 AM
Your on the right track. I would pull it, remove the tins and clean all the grass clippings out and replace the ignition module. It would also be a good time to inspect the front and rear seals for any leaks. Then you will be good for another 20 years.
Old 05-16-2015, 10:15 AM
having some issues with my 2072...was mowing today everything was doin fine for about a half hour, then the motor started choking down...I shut it off, started it again ran for maybe 10 minutes then the same problem..this problem continued with no specific run time...may be 2 minutes might be 15
Now you say you have discovered no spark on one cylinder. The planets are starting to come into alignment.
