#31
Could you convert an aqs (QL) K341 to use a starter generator? replace the flywheel, and add the starter pulley/clutch basket and mount a S/G. Might have to drill and tap the block for the S/G bracket.
You'd lose the PTO in the process...But if that didn't matter... Is this possible? Would the engine (oil pan) mounting holes from an AQS line up with a NF's frame holes? It would probably be easier to modify the NF's frame to accommodate the bigger flywheel...
![]() Quote:
AQS blocks are the same. Now, on a 16, they use the side dipstick which will get in the way. You can use the cam cover with a dipstick and get around that issue, or machine a hole in the block for the dipstick tube on the (machines's) RH side. S/G bracket bolts up to where the starter bolts on the AQS motor, no mods necessary. Oil pans are interchangeable. No lost PTO the mechanical will bolt on. This really isn't a difficult thing. |
#33
![]() Quote:
I have a silly question. Does the aqs have a different shroud to accommodate the flywheel, or is that the same?
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
#35
Ian,
Are you talking about the flywheel shrouding? If so, yes it is different. Has a bump out to accommodate the starter. ![]()
Josh Diesel Cub Cadets........... |
#36
The AQS flywheel shroud is larger than the older ones to accommodate the ring gear on the flywheel. Yes, it also has the starter cut-out.
Nice thing about the AQS engines is they all use the same flywheel and shrouding from the 10-16hp. 8hp (800) was different. |
#37
Exactly what I was curious about. Thanks!
