#31
I manage a parts store, electrical stuff is non-returnable as in no cash refund, however an exchange for another( if faulty) is no problem. Cadet regulator is VR-220 in Standard ignition parts.
#32
Mark:
I like the idea of "remoting" the V/R for testing and adjustment.
#33
If your going to go to all that trouble to remote mount the V/R, why not just set up a "test bench" with a S/G and an electric motor? Then just take the V/R off and hook it up to the test bench and set it up. 3600 RPM 2HP electric motor, basket pulley, belt and a S/G..... a couple wires...
![]() ![]() You could even use the test bench to test S/G's.
#34
it is more fun the udder way, engine running and shaking...just takes up more room.
Here is a link to the v/r.... http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
#35
#36
I had the S/G rebuilt on my 70, and when I started it, the digital meter showed 15.6v. I like to see 13.8-14v with my tractors. That seems to work well without any battery issues.
Some regulators have a screw inside that allows you to adjust that spring. Others simply bend a tab to give the spring less/more tension on the points. Shouldn't be too terribly difficult to do. The one on my 70 has a screw for the field coil points and for the cut-out points. Our Originals require the spring tab to be bent accordingly. Is the voltage regulator up by the headlights on a 149 like it is on my 70? I used a needle-nose pliers to adjust the spring tension while someone else held the meter on the battery terminal and "A" stud on the S/G.
No, it's under the seat next to the battery.
#38
