Old 02-19-2016, 03:43 PM
ab147's Avatar
ab147 ab147 is offline
pics of crank
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 02-19-2016, 05:23 PM
You run it out of oil?
Probably a waste of time but I'd take a piece of emery cloth and clean that crank up and mic it. If you get lucky, a new rod will fix your problem.
Old 02-19-2016, 05:52 PM
ab147's Avatar
No I didn't run it out of oil, in fact I have 2 149's that this has happened to. I'm going to try cleaning up that crank and see what it will read.
Old 02-19-2016, 06:38 PM
You can't clean that up with emry cloth. That crank is done. Rebuild time.
Old 02-19-2016, 08:10 PM
I'm no mechanic and I don't like the look of the scoring on that.
Old 02-19-2016, 09:02 PM
I'm a machinist and just by looking at it, it's scored too much to clean up to factory specs.
replacement crank time
Old 02-20-2016, 01:28 PM
ab147's Avatar
spent a little time with some emery cloth today, and the crank cleaned up pretty good, I don't know what the numbers are, or what they're supposed to be as I don't have a mic this big.
Old 02-20-2016, 01:54 PM
Merk Merk is offline
Crank looks to be too rough to use as is. It needs to have a mirror like finish.
I would take the crank to a shop that can grind cranks and let them take care of it. A good shop will check the crank in 6 places (left side-middle-right side and 90 degrees from first measurement. Kohler service manual shows how to measure the crank.
By doing what you have done may have undersize the crank journal too much to be useable.
Project Uncle Dick
Cub Cadet 70
Old 02-20-2016, 01:59 PM
ab147's Avatar
I just wanted to put up some pics to show how it cleaned up just using emery cloth. I rebuilt a harley shovelhead years ago, and that wasn't real difficult, hopfully this won't be either.
Old 03-13-2016, 05:19 PM
biggie56 biggie56 is offline
Smile
That crank don't look to bad. Take some crocus cloth to it and it will polish right up!
When I was a kid I ran cranks far worse looking than that in my old gokart engines
with scared up used rods! A little bit of elbow grease and it will shine like a new dime!!
Then mike it and see what you got.
2 originals, 105, 123, 124, 2 149's, 682
