#31
Hank, there is supposed to be a spring clip to push the screen against the nose frame, secured by the same bolt in the center that holds the hood to the nose piece. Same bolts also holds the wire clip if you have headlights
Problem is, it only secures the center of the screen leaving the upper corners to flex. I used a couple short pieces of 1/8" or so vacuum hose spilt down the center around the edges, seemed to help some if you bend the screen a little so the hose stays in place against the nose casting. A little dab of silicone (aka blue/black glue) keeps the hose in place. |
#32
So let me get this right .The bolt in the middle holds 1/2 in of the screen on top, hinge at bottom and pressure against the bend of the sides were supposed to hold it in place [not trying to be sarcastic ,every bodys pics look so tucked in at the corners i thought I was missing something]
