Old 11-06-2014, 04:49 PM
Glad to hear you are doing it right. Something for you to remember as you grow older "You can always afford to do it right the second time" I was taught that many years ago.
Thanks Sam, I agree. and it's all done and seems to be ok, I hope.
Old 11-06-2014, 04:50 PM
jimbob200521's Avatar
Better to be taught that lesson that learn it the hard way
-Ryan
Old 12-23-2014, 12:35 PM
Inactive Member
Hey guys, I'm having the EXACT same problem! Oil smells like gas and the top of the carb/bottom of the air filter is covered in oil. I priced a fuel pump at $80 at my local cub dealer... Runs bad and hard to start also... New fuel pump or bypass and what else?
Old 12-23-2014, 12:44 PM
I'd bypass the pump to test that it is in fact the pump and not the carb. Drain the oil refill and replace the oil filter.
Just Googled the Kohler part number for the pump (52-559-03-S) they are priced all over the place looks like from $35.00 and up.
https://www.google.com/#q=kohler+52-559-03-S+
Old 12-23-2014, 12:57 PM
Inactive Member
Sam, when I do get it running, a very small amount of oil will come up through the small tube that is under the air filter... Breather tube?
Old 12-23-2014, 01:06 PM
j4c11's Avatar
j4c11 j4c11 is offline
I think you will get that if the oil level is too high, which, if you got gas leaking into the oil, it's going to be higher than normal because of the gas.
Old 12-23-2014, 01:28 PM
Yes, that is the breather tube. When the oil gets thin with fuel it will puke more oil. Get the problem fixed first, then see how it acts. It's normal for a small amount of oil to come into the housing from the tube, but minimal.
Old 12-23-2014, 03:06 PM
Inactive Member
Thank you all for your prompt replies! Thanks Johnathon, I really appreciate your reply... BTW, I really enjoy some of your replies to the knowledge challenged!!
Old 12-23-2014, 03:15 PM
What ever you do, don't continue to run it with gas diluted oil or it will go bang and you'll join the see through block club.
Old 12-23-2014, 04:21 PM
Inactive Member
Yeah, the 2072 was taking a break from lawn mowing duties and the other day I wanted to get her out to stretch her legs... She really didn't want to! She's in the shop now with the hood up and ready to get a fuel pump bypass. Just have to let my back rest a day or two so I can make the diagnosis!
