Old 07-09-2014, 05:52 PM
Originally Posted by specthompson View Post
https://www.youtube.com/watch?v=2aVn...ature=youtu.be Here is a video of it running. Tell me if the carb needs adjusted or timing or whatnot.
Not really long enough to be able to tell anything.
How does it start?
Did you tune the carb?
Did you time it?
Did you plane the head?
Is there any smoke out the breather?
Where is the head tin work?
Rev's fine, but the way you did it, even if it was lean it probably would.
Old 07-09-2014, 05:53 PM
From the sound of the video it seems fine? Are you still having the same problem? It looks like it responds to throttle pretty well now? It could just be the video put it sounds like bearing (pto/SG?) might be a little loud. I agree with J that it was a little short to get a great idea of what it was doing. It does need to have the motor tins installed at some point soon.
If its running pretty good now I would just keep an eye on the plug to monitor the lean condition and fatten it up if you start to see it happen again. I've been, right or wrong, of the opinion that you don't have broken parts and that doesn't sound like a motor with serious issues to me.
Old 07-09-2014, 05:55 PM
specthompson specthompson is offline
I cleaned up everything then reassembled it before i seen your post on planing the head. I tuned the carb a little, idles a lot better and likes higher rpms a little bit more now. Starts on the turn of the key like it has from day 1. I dont have the right tools to do the timing on engines
Old 07-09-2014, 05:56 PM
You don't have a test light or a multi-meter? You can get a test light for $3 at an auto-parts store. A timing light is not necessary. IMHO, it's a waste of time. Takes all of 5 min to time one with a test light.
Old 07-09-2014, 06:20 PM
Yes this is a simple way to do it for someone that has been taught how to do it. What Jon is saying is to just connect a test light to the points and to a power source at the moment that the points open the light will go out, that needs to be at the proper time that the mark on the flywheel shows up in the hole in the blower shroud. As far as planning the head goes check out this thread.
http://www.onlycubcadets.net/forum/s...ead.php?t=5656
Old 07-09-2014, 06:38 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
don't rev it up at the carb, that over rides the governor. use the dash throttle and rev it up that way you know it actually hits 3600. missing allot of tin work. after you put the carb back on did you adjust the governor as per the manual?
Old 07-09-2014, 07:21 PM
I should have explained. But, for reference it's in the tech section. You can do it the same way the Matt G. did, but with the key on, using a test light. (Same as Sam's description above.)
Here's the link for timing procedure in the tech section:
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
Old 07-09-2014, 07:23 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Just my, but did anybody ask if he was running the correct plug?? I have seen too hot a plug cause all the symptoms above. I have also seen it cause the "hot spots" in the cylinder. Coupled with a too lean condition can be DISASTEROUS!!!! Good luck!
Thanks and I did not adjust the governor. All the tin work is there it just doesn't have a grill or headlights. Im running a champion h10c
Old 07-09-2014, 07:32 PM
No, all the tin-work is not there..... It is missing the tin work over the head at least. Does it have the tin work behind the carb? How about the opposite side?
You need to adjust the governor. You needed to plane the head. You need to check timing.
The spark plug is the correct one.
