Old 11-13-2013, 10:11 PM
Nixon327 Nixon327 is offline
Originally Posted by C5rider View Post
Just noticed you've got the uber-rare twin-hitch option!
Well, that probably makes up for all the other metal that wound up in the dirt somewhere when the tractor was sitting all those years.
Definitely gonna get a few gallons of PB-Blaster for Christmas I see. But, except for those few areas where the northbound rust and the southbound oxidation met in the middle of the panel, I'll bet there's still a few areas that are pretty solid on the ol' girl yet. Will be VERY interesting to see what the INSIDE of that housing looks like.
Keep up with the pix, and thanks for sharing!
That's what I'm thinking. Because as of now it is stuck in neutral. It will not go in gear at all. For the life of me I can't get the roll pin out of the front axle pin. I broke the steering spindle trying to break it loose to get the front wheels to turn. hopefully by this weekend I will have it down to bare frame. The good news is I got the clutch pedal to move! Things are looking up!
Cub Cadet model 70
Cub Cadet Model 109
Definitely a work in progress!
Old 11-14-2013, 12:32 AM
Sometimes your the windshield, sometimes the bug. I think this ones the bug.
I wish you all the luck man. There's a ton of work needed on this tractor, I can understand the sentimental value of things, but..... If you see this project all the way through, your a better man than me.
Old 11-14-2013, 10:21 AM
johncub7172's Avatar
I cant help but to go along with the friendly advice given on your current frame situation,.... and will probably end up with my foot in my mouth,...BUT, if a nice narrow frame pops up I would buy it to replace what you have. You can save your self a lot of work . But then again, you could have a Ace up your sleeve and I'll fold!
Here is my frame to my model 72 in it's present state. Waiting for spring to begin my build:
Good luck, please keep us posted in matter of your frame!
Old 11-14-2013, 12:19 PM
Will do. Its going to be some work involved. But its something I've been wanting to do for a long time. Thanks guys!
Cub Cadet model 70
Cub Cadet Model 109
Old 11-16-2013, 08:57 PM
Default I've got some more work done today
I did some more work on the the 70 today. I removed the clutch, and unbolted the rear end from the frame. Next up is getting the roll pin out of the front axle pin to pull the front axle. I also need to find a good penetrating oil to get what ever is left of the bolts that bolt down the shifter. i thought about knocking the heads off and then worrying about it. Any help would be greatly appreciated.
Cub Cadet model 70
Cub Cadet Model 109
Old 11-16-2013, 08:58 PM
I am extremely jealous of that frame! Man, that thing looks amazing!
Cub Cadet model 70
Cub Cadet Model 109
Old 11-16-2013, 09:07 PM
C5rider C5rider is offline
might I suggest PB Blaster or Justice Brothers JB80
I've had great success with both. PB looks like they haven't changed the artwork on the can since the 50s and JB80 seems to wick into rust pretty well, if you give it time to work it's way in.
http://www.pbblaster.com/ (be sure to have your speakers turned down!)
http://justicebrothers.com/products_specialty.htm#JB80
I've found that if you soak it several times throughout a week or so, it'll really help to break up the rust. Give 'em time to work their way into the rusty areas.
Old 11-16-2013, 09:27 PM
My service van has no less than 3 or 4 cans of PB blaster on it which is what my company supplies us but have been reading a lot on tests of all of them including kroil, liquid wrench, and it always seems a home brew of ATF and acetone wins out on penetrates. I've never tried it but always wanted to. I think you should try it Randy and lt us know. Good progress by the way, keep it up
Edit: good advice Andy, have you done any articles on penetrants in the past?
Old 11-16-2013, 09:41 PM
I was thinking of doing that exact same thing but wanted to make sure. I will pick up acetone and atf this week. Would that mixture eat a plastic spray bottle?
Cub Cadet model 70
Cub Cadet Model 109
Old 11-16-2013, 11:26 PM
Thumbs up
Thanks, I have worked hard to have that frame. The folks at OCC have helped me in the restoration on my 72!
I'll sit out on the shifter plate cover, just be mindful of the fact that the transmission is cast iron, so be careful not to mess that up in anyway. I don't think I ever tackled, or seen anyone tackle a rusty situation like this. Show us what you got!
Woman's nail polish remover and ATF? I have been wanting to try that.
