Old 08-06-2013, 12:24 PM
M&W nine speed for CC, NOS.
(I've seen a couple come up for sale. Just grab yer wallet!)
NOS! You guys are being kinda picky!!..... How about we settle for used...
I have worked on the M&W 3 speed for the 8N ford tractors, which makes them a 9, or is it a 12 speed (can't remember how many gears the 8N had) Anyway, it would run faster than I wanted to drive it down the road!!
Old 08-06-2013, 04:59 PM
jimbob200521's Avatar
There is a $10 "finders fee" for any and all parts I locate. LOL!
Tell ya what, I'll split the difference and call it $5 because I found the same shroud on eBay but wasn't sure it'd fit because it's from a John Deere and they're just...weird
Come on, I dare ya, give me a part you can't find, I'll find it. You may not have the money to buy it, but I can find it!!
That sounds like a challenge!
-Ryan
Old 08-06-2013, 06:17 PM
rweaver rweaver is offline
nos 402 haban sickle bar mower or a complete nos tractor old IH built one the M&W is a hard find and so is the recoil for a original I knew where there was a nos original in the crate some years ago I chased it but then the trail got cold never did find it if it went like his dads other stuff he drank it away
Old 08-11-2013, 08:23 AM
Update: After gathering all my parts, I finally got some wrench time Saturday on the 682. Since I had gotten the carb off and cleaned earlier in the week, I installed rebuild kit, put the carb back on the tractor, drained the 2+ year old gas out of the tank, changed the oil, installed the new fuel pump, new fuel line, new engine shroud, and finally turned the key. After the carb got primed, she fired right up. Before, the choke would have to be 80-90% of the way out to run, but as for the rest of yesterday, I didn't even need it out to start it again. I took it for as easy test spin around the block and once I was confidant everything was in order, I hooked the deck up and test mowed a strip of yard. Worked great so I pulled her back up to the house and shut her off. Let her cool down and changed the transmission filter and fluid. Fired it back up and went back to mowing. Even found some heavy, think weeds out back to test her out on. She didn't even know it was cutting down 1ft tall think weeds at 3/4 throttle, very impressed by the 682, as long as it doesn't throw a rod she's got plenty of power
Thanks guys for the advice on this one and thank you to rweaver for helping out with the engine shroud, you'll be hearing from me again on other parts
Gunk build-up wasn't too bad, worst part was getting whatever gasket sealer the PO put on off, stuff was like solid rubber everywhere
-Ryan
Old 08-11-2013, 09:10 AM
Glad to hear you got it running good!
Old 08-11-2013, 10:07 AM
Great job on the 682! You'll really enjoy it!
