Old 10-30-2012, 05:45 PM
Originally Posted by xtreamedrtbker View Post
So I just got my hands on a Kubota z482 engine from a friend tonight. I think that the 147 may end up the 147D...
Just my 2 cents but I don't think a z482 has enough power for the job. Looks like just under 10HP from what I can find out.
Way cool build.
Old 10-30-2012, 08:32 PM
xtreamedrtbker xtreamedrtbker is offline
The one I have is rated at 13.3hp. Also I have talked with a local diesel pump rebuilder and he said that he could do something with injector size if there is a problem with power. I figure with the flat torque curve and touch more torque it should be equal to the k321.
Old 10-30-2012, 10:39 PM
CC1450's Avatar
CC1450 CC1450 is offline
awesome work on the cab, keep us posted!
-Mark
1978 1450
1976 1450
Old 10-31-2012, 10:38 PM
ksmith's Avatar
ksmith ksmith is offline
Your cab is too cool. I wish I had one when the snow's flying!
Old 11-01-2012, 09:34 PM
Sugarmaker's Avatar
xtreamedrtbker,
Great fab work and details in all areas! This is a very good thread on your cab build and upgrade of the 147 to a comfortable snow moving machine. WOW!!!!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-02-2012, 11:29 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
that cab is cool you going to put some kind of caution light on the top?
Old 11-04-2012, 02:17 AM
Default 147d
Thanks everyone. I am happy to say its coming along nicely and the first test fit of the Kubota z482 is going very well. I will be do more work on it in the next few days and upload photos as quickly as possible.
I got one complete engine and one in parts (spun rod bearing).
Adapter machined for the drive. The adapter is dowel pinned to the crank pulley and held in place with the main crank bolt.
Drive shaft adapter fitted.
First test fit. I'm happy to say it will clear the stock front cross member on the frame once the "bell housing plate" is trimmed.
Old 11-04-2012, 09:21 AM
That should give you some extra HP!
Old 11-04-2012, 11:06 AM
That is neat! I'm enjoying this thread!
Old 11-05-2012, 01:09 AM
Still debating on the type of yellow hazard light I want to use. Thinking flashing LED. Any ideas?
Got the engine positioned right where the Kohler was and mounts welded up.
Test fit hood. Going to have to do something around the alternator bracket.
Thanks !
