Old 04-26-2012, 10:16 AM
OK here we go. Another thing to think about is, if the radiator is by the steering column where will you put your battery or fuel tank?
Not much room back there:
Old 04-26-2012, 10:59 AM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Thanks DX3 for the pics. I'm starting to understand more now. Just curious is the 782D's crank a keyed 1" shaft?
1200, 1450, Red 782
Old 04-26-2012, 05:59 PM
It's a stub shaft that bolts on to the flywheel. It's probably 1" but I don't know for sure...never had mine off.
Any of that fan stuff could be made with steel plate and angle iron, some pillow blocks for the fan shaft, etc. Nothing overly complex about it.
Old 04-26-2012, 10:18 PM
I had to replace the fan bearings in my 882. I used a Grainger part #1L041. That is a .75" shaft with a 1.625" OD. Rich Patton was parting a diesel last fall but the parts may be gone by now. Like Matt said, you could fab up a piece of steel and use pillow block bearings. The blade is still avialable from Kubota but the bracket was Cub and NLA. I don't think it would be too hard to make one. Here are some pics when I did mine.
Old 04-26-2012, 10:29 PM
cub1782's Avatar
cub1782 cub1782 is offline
That is one thing I like about my 1782 is that it has a full-sized battery
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 04-27-2012, 08:38 PM
Originally Posted by dje22 View Post
electic fan??
Wondering if a high amp maybe 105 GM alternator would work and allow me to run electric fan and PTO? Isn't a factory 782D alt around 30-40 amp?
1200, 1450, Red 782
Old 04-27-2012, 09:28 PM
dje22's Avatar
dje22 dje22 is offline
I was planning on using an elecric fan setup when i start my diesel swap. Ive got a temp switch so that it cycles on and off depending on coolant temp
David
1200 w/ 44in deck
1000 w/ yanmar diesel.... in progress
Old 04-27-2012, 10:16 PM
Hey Todd
How did you manage to beat up that radiator? Texting while mowing again?
Old 03-22-2013, 12:05 PM
johndeere140 johndeere140 is offline
Default kubota d600 fan
I want to move the fan and radiater to flywheel end of kubota d600 engine. looking for any thoughts and help on this project.
Old 04-29-2013, 08:59 AM
bluecap24 bluecap24 is offline
So has the OP made any progress on his diesel swap? I have a d600 out of a woods that I am think about doing the same thing with. Someone mentioned a pdf of the stub shaft above. Would they be willing to share?
Jim
