Old 09-08-2011, 06:22 PM
william1041200's Avatar
Where was that valve stem hole? Yeah you do great work!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 09-08-2011, 06:53 PM
cub1782's Avatar
cub1782 cub1782 is offline
That thing looks great!!!!!!!! I love the Vredstrein v61 , I can wait to get some for my 1782 Diesel.
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 09-09-2011, 10:08 AM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
Thanks Guys! I won't have any time to work on it today. Hopefully this weekend though.
Ed
Essex, IL.
Old 09-13-2011, 10:42 AM
Arrowhead's Avatar
I got it mostly back together. I'm having some starting issues. I did not run it much before I stripped it down, but I noticed the amp gauge would be way over on the + side, then the next minute on the - side.
Now when I turn the key on, the amp gauge does not move.
Once I start it, the amp gauge is showing -.
With a known good battery, it turns over very slow, once it hits the compression, it stops.
Even with a booster charge on a good battery, it struggles to turn over.
Once running, the engine sounds fantastic.
Any ideas what this could be? I believe all the wiring is correct. With everything painted seperately, could this be a bad ground situation? Or starter generator?
Ed
Essex, IL.
Old 09-13-2011, 10:58 AM
Ground wire.
Old 09-13-2011, 11:09 AM
westofb's Avatar
westofb westofb is offline
Sounds like your points are in need of adjustment. My 149 recently rebuilt 14 hp is in the same boat. I set the points per the service manual, mine starts okay and sounds good, but when you go from idle to wot, she hesitates and bogs down. I am going to reset mine using MattG's method, I would post a link for you, but I am not smart enough to figure out how to out smart my smart phone....lol, I just need to pick up one of those cheap meters mentioned in his how to, find any post made by him, there is a link in his signature that will send you to his personal site.
Good luck, plus, your tractor is coming out real nice and have been enjoying your thread!
Jeff
Brookfield, MO
________________
Old 09-13-2011, 01:42 PM
Arrowhead's Avatar
I went through all the grounds, they checked out good.
I borrowed the starter/generator off my Dads 108. That fixed it!
I've never been inside one of these, anything I should know or look for? One of the posts seems loose.
I'll get some pics up this evening.
Ed
Essex, IL.
Old 09-13-2011, 01:56 PM
Glad you got it figured out. Looking forward to your pics.
Old 09-13-2011, 07:32 PM
Arrowhead's Avatar
Here are a couple pics of the bad exhaust valve compared to a new one.
Ed
Essex, IL.
Old 09-13-2011, 07:37 PM
CC1650Dave's Avatar
wow, that valve's seen better days...
