Old 06-22-2018, 07:30 PM
cooperino's Avatar
So, I picked up tires today for the 129 I got a couple weeks ago.. Now Why the hell people use slime, fix a flat, or any other crap in a garden tractor tire is beyond me. In a car, stuck on the highway with no spare.. Okay I get it. But this PO takes the cake I have never seen this much crap in a tire. Good new is I got the tires mounted just fine. I need to buy front wheel bearings but just greased them for now..
Maybe one of you Hydro guys can tell me about this. I started it up. Raised the idle to about half I touched the hydro control forward and WOW.. Damn thing did a wheelie. Glad I didn't push it all the way. I tried this a few more times and man that thing is way more responsive and touchy than my 1211. No funny noises, its responsive in reverse also. It really really surprised me though. It feels fine as I said. If I slowly engage it and go slowly faster and faster I can control the response. Is this normal on these older hydros?
Old 06-22-2018, 07:40 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by Kjamesm View Post
Refurbished and put on some old headlights and mounted a switch next to the ignition for power to a tow behind sprayer. Also put in an illuminated ampmeter, I wired it up to light up with the headlights.
Nice looking cub...congrats
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-22-2018, 08:41 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
[QUOTE=Maybe one of you Hydro guys can tell me about this. I started it up. Raised the idle to about half I touched the hydro control forward and WOW.. Damn thing did a wheelie. Glad I didn't push it all the way. I tried this a few more times and man that thing is way more responsive and touchy than my 1211. No funny noises, its responsive in reverse also. It really really surprised me though. It feels fine as I said. If I slowly engage it and go slowly faster and faster I can control the response. Is this normal on these older hydros?[/QUOTE]
Sounds like you might have to do a trunion rebuild.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 06-23-2018, 08:10 AM
cooperino's Avatar
Thanks for the direction. Will pull fenders and have a look. After reading some about the trunnion it does seem like the most likely culprit. I will take some pics soon. My guess is corners worn and possible spring.
Thanks again
Old 06-23-2018, 11:57 AM
Thanks again
I bet you find someone removed the cushion springs and made it solid.
Old 06-23-2018, 12:19 PM
cooperino's Avatar
Ok, That would make a lot of sense, I see where your going with this but why would they do that? Doing that I would imagine would be very hard on the hydro and rear end components among other things. Not to mention hard on your neck every time you start to move. I mean I could understand why certain people would think they can do this and have a gain but most people would understand the implications of doing this and not do it.
Old 06-23-2018, 12:44 PM
jjardina jjardina is offline
That's a very nice restoration; almost too nice to mow. I would love to talk to you about what you did with the pto and deck height arms. Mine have surface rust and the handles are cracked and sun bleached.
Old 06-23-2018, 12:59 PM
I think you severely underestimate the ability for "most people" to understand what they are doing. We've seen it on here a few hundred times. Some PO just finds it too difficult to repair the spring pocket, so it gets mounted solid. We've seen them welded, solid pieces jammed in, rubber hose in place of the springs....Lots of stuff. "People" are pretty ignorant really. Like sanding a crank journal with emry cloth to take out scuff marks from a seized rod and calling it "polished".
Old 06-23-2018, 01:06 PM
cooperino's Avatar
LOL, yeah, sometimes I guess I give people the benefit of doubt a little too easily. As far as sanding the journal by hand lol.. All that work for nothing.. What a shame. Too bad ya cant buy oblong bearings to match!
Old 06-23-2018, 02:23 PM
cooperino's Avatar
So, from the bolts under seat and foot rests it actually looked like no one has ever had it apart to mess with trunnion. That's the good news. Looking at trunnion I do see 2 corners on same side have very slight wear. Is this enough to cause the wholeshot wheelies I'm getting ? From what I was reading wear like this usually causes speed fluctuations and coasting type issues.
