Old 08-23-2011, 10:38 PM
CC1650Dave's Avatar
At this point, I'm leaning toward putting it together and running it. It's going to make me nervous for some time, though...
Old 08-24-2011, 01:38 AM
hydrocub hydrocub is offline
I would do the same ...go for it .
Happy Wrenching .....
Old 08-24-2011, 05:01 AM
westofb's Avatar
westofb westofb is offline
Ditto, put it together and run it, the shim that sets there should be stationary anyhow (I guess it could spin every now and then, but most of the time it should just be sitting ther occupying space), they are there to keep the cam from moving back and forth in the engine as it runs, so as the end of the cam spins, the shim will be the wear edge for the cam, not the broken area of the block.
Jeff
Brookfield, MO
________________
Old 08-24-2011, 11:46 AM
CC1650Dave's Avatar
I'm getting the impression a lot of guys don't want to touch this I understand. Thanks to those who have...
For all we know, this could have been a factory defect and it's run fine all these years. I'm going to take some measurements and draw up a sketch of what we're looking at here, as far as the pin and its position in the block.
Old 08-24-2011, 12:04 PM
CC1650Dave's Avatar
Yesterday I emailed pictures of it to the machinist. I just talked to him and he said to go ahead and put it together as well.
He said that there's a small "v" cut into that spot from the factory, to allow oil to get in there on the shimming washers and all. So it looks like the "v" was what chipped out.
Another good point he made is that the pin doesn't even press-fit into that side of the engine. All of the pressure and tension is on the PTO side of the block.
I'm feeling better about going ahead with it.
Old 08-24-2011, 12:50 PM
CC1650Dave's Avatar
Actually, I did drive that pin out the right way in the first place. The pin is supposed to come out from the PTO side to the bearing plate side. I got confused where it reads "out of the crankcase from the PTO side" but now looking at the image, you can see that the pin is coming OUT of the bearing plate side:
Of course it comes out that way, the PTO side is the press-fit side.
Old 08-24-2011, 02:45 PM
Great idea calling the machinist. If I would have had first hand knowledge I would have chimed in but I'm the guy that paid a extra $35 to let the machinist reassemble my engine and set the bearing plate specs. I've done it before but that was 30 years ago. I did do the oil pan and head tho.
Old 08-24-2011, 03:58 PM
Old 08-24-2011, 04:43 PM
Just doing the easy stuff one day at a time! The key is to know your limits of your skill level and tool/shop level!
Old 08-24-2011, 06:49 PM
That's right!
