Old 09-05-2020, 09:32 AM
IHinIN IHinIN is offline
Figured out the linkage. I was able to slide in a piece of 1-1/2”x2”x1/4” angle iron to attach to. It’s held in with three 5/16” bolts through the 3/8” nuts welded under the fender. No modification to the fenders required. There were a couple of pieces of linkage that came with the valve that I was able to cut apart and reuse to make my new links.
File Type: jpg DF2F67F6-F0F3-445F-9382-34005C86A1BE.jpg (29.6 KB, 213 views)
File Type: jpg BA94C39D-12EA-454B-B969-4912A54F27F3.jpg (21.8 KB, 213 views)
Old 09-07-2020, 07:39 PM
Linkage is almost complete. Need to weld a few pieces yet. Got the valve plate mounted to the frame.
File Type: jpg 2A56BD78-574F-4562-8BEE-43D570590668.jpg (24.3 KB, 194 views)
File Type: jpg 1B87B7F5-B4D2-47A4-91AA-51A546E06F9B.jpg (21.8 KB, 195 views)
File Type: jpg D4F8F04D-2026-48FC-B0DA-8A6E4E6ADBC4.jpg (27.5 KB, 193 views)
Old 09-07-2020, 08:36 PM
Looks good from here, are the handles going between your legs?
Old 09-07-2020, 10:33 PM
Levers come through the fenders where a gear drive shifter would be.
File Type: jpg 2A822651-CBFF-48E7-80D4-658DAC6F674A.jpg (25.7 KB, 191 views)
File Type: jpg 0D530735-7CD2-40F8-83E7-0DAD0B48BAC5.jpg (27.7 KB, 188 views)
Old 09-08-2020, 08:11 AM
IHCubCadet147's Avatar
Looks good!
Old 09-09-2020, 12:52 PM
ATernus ATernus is offline
Default Absolutely amazing
Found this site yesterday, joined, and wanted to comment on this immediately, but just got validated today. I came across a 147 with a Johnson workhorse loader, and from the minute i got it home, i was toying with the idea of painting it red if i got it up and running. Its running well, and seeing what you did, now it will definitely be painted red. eventually. I am very impressed with what you did to your 149, and hopefully i can accomplish something similar. Beautiful work, and an excellent job. kudos to you.
Old 09-09-2020, 12:58 PM
Thank you guys!
ATernus, welcome to OCC
Old 09-09-2020, 11:16 PM
Luke Workman Luke Workman is offline
Wow... Unbelievable... This tractor has come a long, long way. Great work Adam!
Old 09-10-2020, 08:30 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
I love it!
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 09-10-2020, 10:03 PM
Thanks guys.
Finished the linkage and bent a couple of hard lines to connect the valve inline with the lift valve.
File Type: jpg A61C6929-70ED-4E38-A35B-A3000BA8369A.jpg (27.5 KB, 146 views)
File Type: jpg 8337C052-79B8-44D6-B75F-D16C6923FA70.jpg (27.0 KB, 146 views)
File Type: jpg 12D9DD34-F93B-466E-BC55-8254CF8B2043.jpg (24.5 KB, 147 views)
