Old 03-18-2009, 07:34 PM
Bob Balk Bob Balk is offline
Default CC 100 resurrection
I spoke with the PO yesterday. Turns out this cub has been sitting for more than 15 years. I can't believe it started up and does not smoke!!
I got the severely frozen axle pin out. It needed gobs of heat and an impact chisel and it finally came out. There was no grease fitting, but I did install a fitting. We shall see how long the axle holds up after all that heat and a new hole.
I got the points wire reconnected and the cover installed into the repaired holes. Much nicer to have that cover on tight.
I also got my steering shaft back with a new thread end welded on and a much nicer cap nut to hold on the wheel. Much better than the long bolt protruding an inch or so out of the center of the wheel.
Rain tomorrow so I hope to get the front end back together. I will also reassemble the steering gear with fresh grease.
I wish I had a digital camera to show you guys my slow progress.
Oh, I also got an email back from Merk on the PTO. I may also try to dig into that tomorrow. Seems like a good project to tackle while the engine is sitting on my workbench.
