Old 04-17-2011, 11:10 PM
TEET's Avatar
TEET TEET is offline
Great progress so far William...I like the custom rock shaft work, sweet! I was going to recommend swapping to auto release valves..then you picked up the ported pump, lol..nice score
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 04-17-2011, 11:33 PM
william1041200's Avatar
Thanks! Im so amped about this project! Cant wait to get my sickle bar too! Kinda can't wait for snow, to try out my new thrower also( hope nobody wants to kill me for that last comment! )
Old 04-18-2011, 09:36 PM
For those intersted, I pulled the 107 hydro back out, and tried to put in the 1811 rear. Cam plate has a bolt thru ball link that hits my frame tunnel. To see more, go to my post of today, http://www.onlycubcadets.net/forum/s...ad.php?t=10195
Thanks for following! This is a PITA!! Can't wait to see it back on duals and drivable again!
Old 04-18-2011, 09:40 PM
William you've got to be nuts doing this conversion! I'm glad it's going so well for you. Thanks for all the updates! I've been following your progress.
Old 04-18-2011, 09:48 PM
Thanks Duke! Today, after I dragged the 1811 rear to far end of driveway for cleaning, my friends 3 yr old took a big old handfull of sand and dumped all over it. I was gonna beat him silly, but decided he could sit on bench and watch me and my little girl play. Oh you should have seen him squirming! Great punishment that was! Violence is never necessary!!!!! Tempting, but there are better ways.
Old 04-19-2011, 12:09 PM
westofb's Avatar
westofb westofb is offline
Just be thankful you didn't have a cover off and had sand poured inside of it!
Jeff
Brookfield, MO
________________
Old 04-19-2011, 01:11 PM
So true!
Old 04-19-2011, 05:30 PM
I would have beat myself for leaving it open around a 3 yr old.
Old 04-21-2011, 09:46 PM
Default great progress!
Ported hydro rear is transferred to my 107 transaxle! Went pretty smooth. I have a couple questions illustrated in these pics. on the IH 107 rear there is a gasket with 3 holes. 2 holes (outer positions ) are for small bolts in pinion gear housing. What is the lowest center hole for? The CCC rear and pump didnt have the bolts, or the low center hole. I put it together anyhow, but should I be worrried about it? Im thinking its an oil flow return hole for the pinion bearings. If the oil can flow in, it can flow out. Im thinking.
Old 04-21-2011, 10:07 PM
I did notice , and I had been thinking of this before, that IH ran the oil supply line up over the charge pump then back down under and to the charge pump. The CCC setup went straight to the charge pump. No interference, no problems. Anyone have any ideas why IH did that? Seems like a bad engineering decision to me. Just over thinking a simple ripple in fluid paths. Something CCC did right.
