#21
Nice pics Roanoker . Thanks for sharing . Good luck on your rebuild .
I'm just down the road from you in the NRV . |
#22
The process has started, I just ordered a Stens gasket kit. Going to check with the local dealer on the other parts before I start much searching online.
Johnnie Watkins All original Model 800, what else could I want? "Thought I was wrong about something along about three years ago, but as it turns out I was only slightly mistaken." |
#23
![]() Quote:
Now that the history lesson is over..... I have family around Claytor Lake and I am through there sometimes, I catch I-77 and run it into Bluefield West Virginia.
#24
I have relatives in West Jefferson, North Carolina along the New River . It is a very very interesting river
#25
There be some mighty big catfish in those waters also. I have a buddy that lives on the New River, right were it comes out of West Virginia, and we drug a 70lbs mud cat out on 30lbs test line. Took the two of us working together for two and a half hours to finally get the thing on land.
#26
Very nice Roanoker!! I like a little history and geography. Thank you, very nice!
#27
Your clutch plate cracking is likely caused by drive shaft mis-alignment. I'd check the engine mounts. I had a 1200 with the same problem.
#28
Thank you for the info. After the mess I found inside the engine I had forgotten about the drive plate being cracked. I will check those mounts before I install the engine.
#29
I would just replace the mounts with new OEM ones while you are in there, and do the crossbrace mod at the same time. Then you won't have to touch it again.
#30
![]() Quote:
Edit: I know I seen NOS iso mounts on one of the sponsors links, I will just have to remember which one it was.
