Old 06-14-2024, 05:28 PM
CubbyLover2021 CubbyLover2021 is offline
I did however find her first real issue. Nothing terrible, but the carburetor is leaking at the bowl gasket. Is this as simple as buying the bowl gasket kit or is the float causing the issue?
The good news is if I shut off the fuel and the the carb dry, she doesn't leak. So I do have a work around.
Old 06-14-2024, 07:56 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by CubbyLover2021 View Post
And maybe someone can help me with a trick on how to get the steering column bushing back in the steering shaft. I can get it slightly inside but it won't slide down in. I tried removing the steering wheel but that's an effort in futile without a bearing puller or something. I really feel like I can get this thing back in place without removing the wheel.
My experienced has been that if you try t0o replace the bowl gasket while the carb is on the engine, you almost have to be Houdini to get everything back together.
It's may be just me, but buy a carb kit, take the carb off and do it right and do it easy.
Old 06-14-2024, 09:17 PM
A gentleman on another forum suggested doing it with the carb on the tractor, but using a dab of grease to hold the gaskets in place.
It looks like it's two gaskets in the bowl. The thin o ring and the other weird gasket that kind of hangs outside the bowl... See attached pic.
