Old 12-24-2023, 11:43 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Nicely done. Getting the PTO clutch off was the hardest part of rebuilding my K241.
Old 12-25-2023, 12:14 PM
Glad you got it off, you obviously took the patience approach. It is
truly the only way to get it done without head banging.
I realize your a ways from putting it back together. Maybe while waiting
on parts and such. Give the PTO a good cleaning and especially where
those set screws were at. Chase the threads nice a clean. Run a little
oil in the threads. I would also consider replacing all the set screws.
You will be glad you did when reassembly happens. And if you ever
have to take it apart again. Easy Easy.
Ken
Old 12-25-2023, 07:06 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Good work!
I found an old Cub driveshaft makes a fine bar to use to pry off the PTO clutch a bit at a time, working your way around the housing.
Looking forward to your progress and pictures.
Merry Christmas!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-27-2023, 10:12 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
I’m this far. The last set screw here is pretty stuck. Out of all our Allen wrenches couldn’t seem to get one to fit 100% perfect. Spun out a couple times…
https://www.onlycubcadets.net/forum/...pictureid=8394
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 01-01-2024, 03:03 PM
LAWN BOY's Avatar
Had to heat up that temperamental set screw and sacrafice a screwdriver, but eventually got this far. Will have to carefully drill out the remains of the set screw. We are unsure how to remove the cam… As far as I saw, the manual explains reinstall, but not dissassembly...
https://www.onlycubcadets.net/forum/...pictureid=8396
https://www.onlycubcadets.net/forum/...pictureid=8395
Old 01-01-2024, 07:27 PM
LAWN BOY's Avatar
Got the camshaft out.
Old 01-06-2024, 05:46 PM
jbrewer's Avatar
You're making good progress.
Thanks for sharing it. Post some pics :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 01-06-2024, 10:46 PM
LAWN BOY's Avatar
JBrewer, the most recent pics I posted were as links just a couple posts back. That’s pretty much how far I am right now.
Old 01-08-2024, 10:52 PM
LAWN BOY's Avatar
Default Should I repaint it?
Do you guys think that I should repaint the motor the right type of yellow while I have it all apart? I mean, it‘s pretty much going to be a new motor inside, might as well be outside. I didn’t even really consider the idea until my dad mentioned it. I think it might look weird with the way the rest of the tractor looks. Although I could restore the whole tractor next summer, but that seems like a lot of work to me. I’m going to put on new tires next summer so might as well repaint the rims while the old tires are off and new ones aren’t on yet. Problem: We do have a nice warm 70 degree F attached garage, but can’t really spray much in there because it’s attached and well fumes. It’s winter here in Wisconsin. Do you guys think I could get away with painting the motor parts outside in the 20 something degree weather and then bringing them in to dry?
Old 01-09-2024, 07:51 AM
ironman's Avatar
ironman ironman is offline
If you think that you might repaint the whole tractor, then now is the time to paint the engine. This will be the last time it's spiffy clean and completely apart.
Painting parts outside and bringing in will work, and while you won't have to worry about fumes, there will still be paint smell while the paint dries, so better check with the folks first.
