Old 11-02-2023, 12:59 PM
Doc Brown Doc Brown is offline
Thank you. Those look like quality for sure.
Old 11-02-2023, 01:03 PM
Old 11-02-2023, 09:16 PM
Looks like the real deal but I think it should say Carter on it? If it is
the original Carter the kit for it would be 25-757-01. I hope it is as
I think you will have better luck in the long haul with the OEM carb.
I know I certainly have.
Ken
Old 11-03-2023, 07:57 AM
Ken
Hi Ken.
I don't know what numbers are supposed to be stamped on it to know if it's the original but my gut tells me it is. Did Kohler use any other manufacturer other than Carter? The carb feels pretty chunky compared to the chinesium one that I took off it.
Old 11-03-2023, 11:08 AM
Hey Doc, I don't know the answer to your question about other carbs
being used on these engines. Hopefully someone else will know that.
I have 4 carbs here for K301s and they all have the Carter Model N
stamped in them.
Compared to your pictures they are similar but not exact as you see.
Ken
Old 11-03-2023, 01:27 PM
Your carb is a Kohler carburetor.The later ones did away with the Carter.
Old 11-04-2023, 12:01 PM
Will the same kit work on the later ones or do you have to look it up
under something else?
Ken
Old 11-04-2023, 12:05 PM
The later Kohler and Carter carbs it will work on, it will not work on the Walro marked ones...
Old 11-04-2023, 05:13 PM
Thank you sir.
I'll order a Kohler rebuild kit for it.
Old 11-04-2023, 05:18 PM
stamped in them.
Ken
Thanks I guess my carb is a Kohler which I can order a carb kit for.
