#21
Quietline 1250
#22
If the charge pump fails completely there won't be any "make up" oil to supply the pump and it won't move. Usually if the transmission is weak, it's because of damage to the brass port plate(s) allowing oil to bypass rather than build pressure. If the hydro is weak and noisy, I'd quit running it, regardless.
#23
Quietline 1250
#24
For 99.9% of shops they are replaceable but not repairable. I spent the last 28 years of my working life in a hydraulics rebuilding shop. We had specialized equipment and process's to refinish many parts rather than replacing them. It was a niche specialty and saved our costumers, big and small, a lot of money and time. There is "hydraulic whine" but a rough whine is likely damage. And since you have whine and poor performance, that's a good indicator.
You can remove your charge pump after removing the driveline. Tomorrow, I can takes some pics to indicate areas that usually wear. And they go downhill real fast. |
#25
With the vast supply of good used Sunstrand hydro units, I would not bother rebuilding the unit. I've rebuilt them, and they are pretty straightforward, but financially, you will be ahead just getting a good used unit and swapping it out. Just get a new cork gasket for the hydro to transaxle mating surface. These rarely fail, even being 30-50 years old.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#26
Quietline 1250
#27
The most common failure is on the lens plates. Obvious scoring between the ports is easy to see. In the one pic, you can see a score line going from the pressure side of the pump the slack side, caused by contamination. In bad cases a large groove will join all the ports.
Notice the motor side has four V shaped notches and the pump only has two. Sometimes there are scratches on the brass piston slippers too. That’s always from contamination. |
#28
Quietline 1250
#29
Yes, that is it.
#30
Ok so I got two valves from a buddy and put them into my hydro, no difference. I put my valves in his hydro, no difference. I found another unit from a 149 and purchased it. This will be my first time tearing this far into my machine. Any tips would be greatly appreciated. Also what should I use and what is the best way to clean up my new used hydro without getting any junk inside of it?
Quietline 1250
