Old 06-24-2022, 07:06 AM
Club Cadet Club Cadet is offline
Originally Posted by Cadmandu View Post
Plus I'm buying 5 gal of non ethanol
A full tank of fuel these days will raise your tractor value by $20 alone
Old 07-03-2022, 09:34 AM
Cadmandu Cadmandu is offline
Well after all this work the mower still runs 30 minutes gets hot and shuts off.
I will install new plugs and check for spark. What should the resistance be on the secondary of the ignitioin module between the two plug wires?
Can this be replaced and air gap set without pulling the engine?
thanks for all the help.
Old 07-03-2022, 09:46 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I have a M18 that would run for about 10-15 mins then shut off and would not restart until it was cool. The magneto was the culprit. A new OEM Kohler magneto fixed it. The engine should be pulled to properly replace it. Also, ensure the fuel system is venting.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 07-03-2022, 04:40 PM
That sucks! That would be pretty tough to pull the blower housing with the engine in the machine. I'd just pull it out and remove the shrouds and give it a good cleaning. Probably wouldn't hurt to pull the flywheel too and inspect and clean everything behind it too. I know, a lot of extra work but it really isn't that hard to pull the engines out of these things. There is a testing procedure for the mags and everything else in the manual found here. https://www.onlycubcadets.net/forum/...ead.php?t=4648
Old 07-03-2022, 06:19 PM
Thanks I have a M20. Can I use the M18 manual?
Old 07-03-2022, 06:38 PM
short answer, yes,---- and you can down load it free if needed.
I'm betting you will find a wad of chit around the magneto coil, never saw one that didn't have an accumulation there.
Also, look behind the flywheel and you will see chit accumulated there in the stator windings also.
Check to see if the "Maggots" are still glued to the flywheel while blowing things clean with compressed air
Treat them good and they will last a long time!
Old 07-04-2022, 09:44 AM
Thanks the ser man is great. The un-noticed mouse nest behind my engine really caused alot of damage. I will be taking an ohm reading soon on the secondary of the magneto. It ran 30 min the other day got hot shut off and then the next day fired right up. I ha ve my 89 F-150 4x4 in the garage now so i will be a few days getting back to you all. Happy 4th and thanks so much for all your help.
Old 08-14-2022, 07:46 AM
Can you get to the magneto easily to clean?
Old 08-14-2022, 08:15 AM
Are your mags any good?
If you pull the engine out, all you need to do is remove the shroud....and if you're that far into it you may as well pull the flywheel. With the flywheel pulled you can clean and inspect the magnets and also do the oil seal for the crank.
I know, that's probably a lot more work but then you can forget about it once it's done.
