Old 02-19-2022, 04:51 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Well according to my specification sheet your Serial number/model was built in 1996 , the first 2 digits identify year made and the remaining digits are the Factory code
All HDS2155 came with the 42" deck
I will scan in the spec sheet and original sales catalogue and post them
Oz
Old 02-19-2022, 05:11 PM
Here is my sheet. I will see yours later or is that tomorrow?
Up to 534 and counting...
Old 02-19-2022, 05:29 PM
click on the link below the picture.
Old 02-23-2022, 06:37 PM
EternalArianne EternalArianne is offline
Ok I found the sticker on the engine, and based on the serial number the engine is from 1996. So unless it's a transplant, the tractor is also 1996. Explains it having an early model deck...
Old 02-23-2022, 11:12 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
The engines are usually older than the tractor, by at least a few months. Because the engine is a sub assembly completed before the tractor. I've seen some 6-12 months prior but 2 or 3 is more common.
Also not real sure why it matters, the difference at the serial number splits is usually not much and easily identified.
JD x475
