Old 08-28-2021, 06:35 AM
crazycubtrio crazycubtrio is offline
Hi Steve, sorry about your Haban troubles. I had a similar issue with a deck belt on my deck too. Just took it off to paint and for the life of me couldn’t get it back on right. I truly believe you just have the routing of it wrong. After I got it routed right I felt like an idiot not being able to slip it right on. Step back, think about how else it can go and still put tension on it . Good luck
Old 08-28-2021, 08:20 PM
CubDieselFan's Avatar
Here is the belt you have coming.
Old 08-30-2021, 01:48 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I run a B114 on both my 375 60" Habans.. they are 117" outside circumference.. B series belts are 3" longer than the number indicates
Jay
Proud owner of the following:
Old 09-01-2021, 12:59 PM
sorner's Avatar
sorner sorner is offline
I think that's about the extra length I would need for it to fit right.
I received it, but I have not had a chance to try it out yet.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 09-01-2021, 01:06 PM
sorner's Avatar
Are you routing the belt to the upper drive pulley or the lower?
Lower. The upper pulley is the PTO belt.
I'm routing it just like the diagram, I've misrouted the belt before on a 50C and made it be too loose. I'm going from the left pulley up around the center on the right side, then around the left side of the tensioner and over to the right pulley. Just like the diagram Roland posted early on in this thread.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-07-2021, 02:18 PM
sorner's Avatar
Well, to put this drama to rest, I got the belt on that Greg (CubDieselFan) hooked me up with, I couldn't get it "over the hump" so I took the spring off and cut 2" off it, and tried again, and I barely got it on. It feels way too tight, I'm assuming it'll stretch out some, but the spring is max compressed even with the 2" cut off. I'm wondering if this isn't the right spring for it, or something. Something's wonky with this deck, but I got the belt on now... we'll see what happens going forward.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-07-2021, 03:55 PM
Maybe the idler has been changed and is not the right size.
Old 09-07-2021, 08:11 PM
sorner's Avatar
What size should the idler pulley be? It is the same size as the one on my 50C. I’m guessing around 4”, I didn’t measure it. I was thinking that could be a possibility too,
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-08-2021, 12:14 PM
I do not know... maybe a haban deck owner will chime in.
Old 09-08-2021, 12:26 PM
I don't think the size of the Idler Pulley matters. The pulley is going to put tension in the spindle belt regardless of size.
