Old 05-11-2021, 12:59 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Well, I may try that , but I found a gauge from one of our friendly online forum sponsors (I think) for all of $4, so that's a deal. I have to order some of those pointy set screws anyway.
I need to go buy some nuts too .. .. the ones on this thing are all buggered up.
I'll look at that shaft collar. You might be right about the source of that extra nut rattling around in there.
(edit: nope... fits neither the locking collar screw or the clutch bolts. )
Thanks Lew!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-11-2021, 01:56 PM
ironman's Avatar
ironman ironman is offline
Hopefully by now you have studied this in the tech library....
https://www.onlycubcadets.net/forum/showthread.php?t=9
Old 05-11-2021, 03:59 PM
jbrewer's Avatar
Default More...
I have indeed studied that... thanks (I've not seen the one with the brake!) . Mine is the single spring job.
Update:
I found another PTO that I forgot I ordered ...oh, 10 yrs ago. It was sold as rebuilt (and looks to be). Long story short: I put it on and have the same result. The PTO clutch works as advertised when the engine is OFF but with the engine running, I cannot stop the pulley with the 2x4.
User ATHOMAS mentioned putting a strap around it when off and trying to start the engine. While I'm not Mister Safety, I may try this with great caution as I'm thinking that maybe what I'm seeing (other than the new clutch button being consumed ) might be that once the engine has started, there's so much rotational mass that it's unlikely to stop?
The downside is that I could take my head off when the bungee strap explodes....
It's unlikely that BOTH PTO's are bad in the same way, so there must be something else. Bearing is possible, but it sure feels OK . It doesn't spin free but feels like it's got grease inside and there's no wobble or grittiness.
Update: Applied bungee in such a way to freeze the pulley in place , then put the clutch lever so that the button was depressed. Took spark plug cable off and cranked it. Pulley stayed in place, and no barnyard noises. Put spark plug cable back on, started engine, and pulley stayed in place and PTO button(s) were stationary of course
So... with no load on the PTO pulley, there's so much rotational mass on that pulley that you'll set a 2x4 on fire before you'll stop it once the engine is running . ATHOMAS, you sir, win the Internet!
I'll reassemble the original PTO once the gauge gets here ($4) with the shiny new jam nuts
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 05-17-2021, 08:18 PM
jbrewer's Avatar
Got the gauge, cleaned and painted, made sure Lew's snap ring was in there and I've got a new spare for the Cub tub.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
