Old 03-23-2020, 07:57 PM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Haven't done much work to the old gal lately. Found out this is actually a k321 and not a k301. So I'm going to take the 14 and drop it into a deere I've got that needs an engine and part out a decrepit 1650 with a 301 ( according to the tin- that has lied to me before). Right now the 1250 is sitting under a tarp until I get time to pull the 1650 engine out and examine it.
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 03-23-2020, 09:10 PM
When replacing the axle pivot with a bolt, make sure it is long enough that the threads end outside of the channel.
You do not want a thread in the channel, or worse, in the axle and channel as it smaller in diameter and counter
intuitive to tightening things up.
You might have to thread the bolt a bit more after you cut the too-long-of-a bolt off to get it just right.
A washer on the bolt then a nut to get it just right, is not a problem.
And as mentioned, the head of the bolt is shortened for pan clearance.
It does not need the full thickness head as it just tightens the channel and is not tightened all that much as it is just retains the pivot bolt/pin.
Old 03-24-2020, 12:41 AM
DownNdirt's Avatar
Thanks George, I'll have to remember that once I get to it. I'm currently juggling about 5 other projects (most are of the green and yellow variety) and don't have time or money to get a whole lot accomplished .
